Adjusting monitor-power-off-time doesn't work -- again
    Hi there,
    with a fresh Feisty installation I tried to adjust my monitor's power-off time. I tried it using the "System Settings"->"Monitor & Display"->"Power saving"-tab. The default was a power-off time of 45 minutes.
    So I switched to Administrator mode and adjusted the power-off time. Fine, I thought. After loggin out, restarting the X-server and loggin in again I had to realize that my changes were simply ignored. The power off-time was still set to 45 minutes. Damn!
    So what is this all about? The thing is that this wasn't working in Dapper and Edgy neither.
    If it still doesn't work, why don't you just drop or disable this "feature"? Maybe leaving a note how to adjust the power-off time by hand in /etc/X11/xorg.conf.
    In fact, the first time I tried to adjust the power-off time, it completely corrupted my X-server configuration, leaving me with a nice 640x480-resolution after restart. Luckily I had a backup of my xorg.conf.
    So I can only advise everybody to refrain from using the "Monitor & Display"-interface.
    regards,
    Christian
    Re: Adjusting monitor-power-off-time doesn't work -- again
    Maybe this ...
    From man xset:
    xset - user preference utility for X
    OPTIONS
    -dpms The -dpms option disables DPMS (Energy Star) features.
    +dpms The +dpms option enables DPMS (Energy Star) features.
    dpms flags...
    The dpms option allows the DPMS (Energy Star) parameters to be
    set. The option can take up to three numerical values, or the
    ‘force’ flag followed by a DPMS state. The ‘force’ flags
    forces the server to immediately switch to the DPMS state spec‐
    ified. The DPMS state can be one of ‘standby’, ‘suspend’,
    ‘off’, or ‘on’. When numerical values are given, they set the
    inactivity period (in units of seconds) before the three modes
    are activated. The first value given is for the ‘standby’
    mode, the second is for the ‘suspend’ mode, and the third is
    for the ‘off’ mode. Setting these values implicitly enables
    the DPMS features. A value of zero disables a particular mode.
    In the konsole:
    :~$ xset -q
    tells:
    DPMS (Energy Star):
    clip....
    Standby: 1200 Suspend: 1800 Off: 2400
    DPMS is Enabled
    Monitor is On
    clip....
    Changing:
    sudo xset dpms 2000 2500 3000
    Check:
    xset -q
    DPMS (Energy Star):
    Standby: 2000 Suspend: 2500 Off: 3000
    DPMS is Enabled
    Monitor is On
    Hmm - maybe in the next version
    Kubuntu Forums > Kubuntu Discussion > Kubuntu Gutsy Gibbon > New Feature Requests > http://kubuntuforums.net/forums/index.php?board=48.0
    K> System Settings > Monitor & Display reads and writes xorg.conf. It does this poorly. It also backups xorg.conf -> xorg.conf.1 (xorg.conf.2...) but doesn't tell this >
    Hmm - minimum should be warning :
    WARNING WARNING WARNING WARNING WARNING WARNING
    THE USE OF THIS PROGRAM CAN DAMAGE YOUR XORG.CONF FILE. IF YOU ARE NOT SURE WHAT YOU ARE DOING (CATCH-22), HIT CANCEL NOW. OTHERWISE, HIT OK TO CONTINUE
    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
    EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
    MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
    Same opinion
    Links:
    HOWTO : Disaster Recovery and xorg.conf
    http://kubuntuforums.net/forums/inde...opic=3082808.0
    Before you edit, BACKUP !
    Why there are dead links ?
    2. Thread: Lost Information
