I'm fairly new to the Kubuntu site but I wanted to post something I thought was sorta strange. About a year and a half ago I gave my friend a Ubuntu cd (first time we had ever heard of it) and it ran perfectly and he got it installed onto his home computer (long story, he had to delete it because of family's lack of understand it, he's going to get Kubuntu this time though since no one uses the computer now).
Well, I tried, back then, to install it and at the install screen it ran when it said "Run as LiveCD/Install" and it crashed, restarted, and did it all over again (also did it in every mode, mind you I was still a MicroSucks noob who didn't wanna put up with anything more then point, click, install). Frustrated I quit trying to use Ubuntu.
About a week ago I finally tried again (I hated Fedora's big brother view of music files, since most of my songs already are in mp3 format, and the lack of programs) and so I installed PCLinuxOS. Before I tried to install Kubuntu it almost didn't work and I tried in safe install (PCLinuxOS I mean).
Safe install had some jargon of how it would run (first time I actually saw the boot script) and it had something interesting that was different from the main install, the final script of "acpi=off". I wrote down everything that was in the Normal Setup and the Safe Setup. I tried changing the original boot up and it happened to work when I put that in. I looked it up it has something to do with power distribution (mind again, I'm still pretty noobish at Linux and would love to learn how to program so I could actually be a bigger part of Kubuntu.)
So alas, I tried the Kubuntu install with this new found knowledge (PCLinuxOS crashed pretty hard on me, and I had to change the script so the boot would always contain that parameter and I wanted Kubuntu for a while now), and... it restarted again. I checked the boot parameters angrily (on the Live CD) and I just went through some weird process and thought (I had written down all of what made PCLinuxOS run) and I saw "hey, Kubuntu doesn't have the 'noapic' thing in it." Tried this, with 'acpi=off', it worked and installed perfectly. Afterwards, it ran without me having to write this in every time or at all when the OS was finally installed.
Now, thanks for those who read that long story of mine, much appricated, but I was wondering if other's not being able to install or run the CD (the one's who usually come onto the forums to rant, the MS-Noobs like I use to be :P ) might be having the same problem? Because, I know my computer isn't the newest but it runs Kubuntu pretty smooth except that weird hitch. Anyways, I'd love to hear some feedback (hopefully from someone who understands it all better then I do).
Greets,
Ash
P.S. If it's in the wrong section, please move, sorry about it if it is.
Edit: I'm running Kubuntu on a...
KDE Version: 3.5.6
Machine: i686
Release: 2.6.20-16
RAM: 512 mb
Harddrive: 80 gigs
If I need to add anything else ask please, I'm not sure what else.
Greets,
Ash
KDE Version: 3.5.6
Machine: i686
Release: 2.6.20-16
RAM: 512 mb
Harddrive: 80 gigs
:P) but basically this whole Mindset of the users from Windows (I had the same problem to, reason why I never bothered with it after that, not even going to boards about it), that if you have to do the slightest work it doesn't work.
