Please go to my last post
Original post:
Hi.
I am trying to install Kubuntu along with Windows XP (dual boot) and I can't figure out how to partition my hard drive to do so.
 I already have Windows XP installed. I have backed up my entire hard drive and defragmented it.
According to tutorials I have found on the internet, there should be these options when in the partition section of the installer:
-Resize main partition and use left over space
-Use entire disk
-Use largest contiguous free space
-Manual
Only the bottom three appear. I chose manual. When I went into the manual partition thing, it wouldn't let me resize my main partition (NTFS format).
 I do not know what to do to get past the partitioning step.
My hard drive has 3 partitions that were there when I got my computer - one is about 240gb NTFS, the main partition that Windows XP is on. The other one is FAT32, about 8gb, and it has data to make system restore discs. Then the last partition is "hidden", it's about 500mb, and I have no idea what it is. I want all these partitions to remain the same, except for the main one which I want to resize, and use the freed space for these partitions:
35gb root (/)
35gb home (/home) OR shared FAT32 partition
2gb swap (swap)
I found a program on the boot CD of Kubuntu called QTParted. It allowed me to resize my NTFS partitions (I didn't resize it though). Is it safe to use QTParted to resize the NTFS partition, then use the partition editor in the installer to do the rest?
Also, if I want to be able to share files between Kubuntu and Windows, do I need a "shared" FAT32 partition?
System Specs:
AMD Athlon 64 Processor 3800+ ~2.4GHz
1GB DDR RAM
250GB Hard Drive
Integrated NVIDIA GeForce 6150 LE
I am using the 64bit Live CD of Kubuntu Feisty Fawn.
So, how would I partition my hard drive and install it? (I want a thing when the computer boots up that asks me which OS to boot into and also to be able to share files between the two operating systems)
Please tell me if you need any more information...
Thanks for your time
					Original post:
Hi.
 I already have Windows XP installed. I have backed up my entire hard drive and defragmented it.According to tutorials I have found on the internet, there should be these options when in the partition section of the installer:
-Use entire disk
-Manual
 I do not know what to do to get past the partitioning step.My hard drive has 3 partitions that were there when I got my computer - one is about 240gb NTFS, the main partition that Windows XP is on. The other one is FAT32, about 8gb, and it has data to make system restore discs. Then the last partition is "hidden", it's about 500mb, and I have no idea what it is. I want all these partitions to remain the same, except for the main one which I want to resize, and use the freed space for these partitions:
35gb root (/)
2gb swap (swap)
System Specs:
1GB DDR RAM
250GB Hard Drive
