Hi all,
Im having major problems instaling Kubuntu from the amd64-DVD the way i want it...
Im unable to boot my fresh installed system!
Let me start with the error im stuck at and after explain my setup.
When i boot i see vt8 and vt1 outputs below, and thats it...
I can't seem to get the system up
My setup is:
I was able to set this all up and install kubuntu without any problems or errors, although the tea-breaks between LV setups is kinda BIG.
Anyone any ideas how to proceed tobe able to boot this system from HD?
_________________________________________________
[vt8] output:
[vt1] output:
Fdisk output:
LVM setup:
All LV's are ext3 and mounted on the obvious named mountpoints, except swap ofcourse which is a swap
My setup is:
- CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
- Memory: 1GB RAM
- Video card: ATI Radeon 1650 pro
- Disks: 1xIDE, 1xSATA
- Partition table(s): See fdisk output and LVM setup below, /dev/sda1 is an ext3 partition mounted on /boot
- Bios boot: IDE-HD
- System is dual booting Kubuntu / Windows XP using GRUB.
- Install option choosen was: Setup server with all 3 extras (LAMP etc)
[vt8] output:
BusyBox v1.1.3 (Debian 1:1.1.3-3ubuntu3) Built-in shell (ash) Enter 'help' for a list of built-in commands. /bin/sh: can't access tty: job control turned off (initramfs) <promt is here>
Loading, please wait... kinit: name_to_dev_t(/dev/mapper/Linux-swap) = dm-1(254,1) kinit: trying to resume from /dev/mapper/Linux-swap kinit: No resume image, doing normal boot... Target filesystem doesn't have /sbin/init <following lines are at bottom of screen> Kernel alive kernel direct mapping tables up to 100000000 @ 8000-d000
~ # fdisk -l Disk /dev/sda: 160.0 GB, 160041885696 bytes 255 heads, 63 sectors/track, 19457 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/sda1 1 3 24066 83 Linux /dev/sda2 * 4 6409 51456195 7 HPFS/NTFS /dev/sda3 6410 19457 104808060 8e Linux LVM Disk /dev/hda: 160.0 GB, 160041885696 bytes 255 heads, 63 sectors/track, 19457 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/hda1 1 16709 134215011 7 HPFS/NTFS ~ #
Current LVM Configuration: Unallocated physical volumes: * none Volume groups: * Linux (107319MB) - Uses physical volume: /dev/sda3 (107319MB) - Provides logical volume: bin (1073MB) - Provides logical volume: home (85895MB) - Provides logical volume: lib (4294MB) - Provides logical volume: root (104MB) - Provides logical volume: sbin (1073MB) - Provides logical volume: swap (8589MB) - Provides logical volume: tmp (524MB) - Provides logical volume: usr (4294MB) - Provides logical volume: var (419MB) - Provides logical volume: var.log (524MB) - Provides logical volume: var.spool (524MB)
