Upgrade Problem
    Upgrade Problem
    I was running Edgy on my laptop, and I tried upgrading to Feisty. Something just popped up one day asking if I wanted to upgrade, so I went ahead and did it. Unfortunately, there was an error while it was upgrading, so it stopped right in the middle. Now I can't start the X window system.
    So here's what I need to know. First of all, how do I enable my wireless network through commands? And after that gets running, how can I restart the upgrade through a command?
    Re: Upgrade Problem
    I guess first you should get the upgrade finished and then get network back it should be easier...
    From the console :
    sudo apt-get -f install
    sudo apt-get dist-upgrade
    Till you get it finished and no more upgradable package exists in the list.
    Hope it helps
