Feisty goes to black screen on logout. Have to reboot to get back in.
logout problem with feisty
Re: logout problem with feisty
This is a long shot guys, but worth a try. Edit your menu.lst and add the "vga=xxx" statement right after the splash statement (add a space between first). I had to do that on two machines to get the Splashes to work, maybe it will help in this case. Again, long shot. The below table are the values for vga:
Code:Color depth | 640x480 800x600 1024x768 1280x1024 -----------------+------------------------------------- 256 (8bit)| 769 771 773 775 32000 (15bit)| 784 787 790 793 65000 (16bit)| 785 788 791 794 16.7 Mill.(24bit)| 786 789 792 795
Originally posted by MoonRiseThis is a long shot guys, but worth a try. Edit your menu.lst and add the "vga=xxx" statement right after the splash statement (add a space between first). I had to do that on two machines to get the Splashes to work, maybe it will help in this case. Again, long shot. The below table are the values for vga:
I used vga=792 and I have a standard 19" Acer LCD and ATI X700 256M
