Edgy to Feisty: Kubuntu distribution upgrade tool problem
    Re: Edgy to Feisty: Kubuntu distribution upgrade tool problem
    I had this problem too. After setting my repositories back to edgy, getting the KDE pre-Feisty packages, and rebooting, the upgrade wizard did work properly. Hopefully this will work for others as well.
    deb [url]http://kubuntu.org/packages/kde-356-pre-feisty-upgrade/[/url] edgy main
      I have the same problem and still no luck.
      I did sudo dpkg --configure -a
      I have deb http://kubuntu.org/packages/kde-356-pre-feisty-upgrade/ edgy main in the repos and did install the pre-feisty KDE packages.
      All packages are up to date.
      But: "Ready to upgrade!" -> "Finish" ->
      Another question: in the the upgrade procedure instructions it says: "If your system is up to date, the upgrade wizard will appear or you can choose it via the Version Upgrade button." What is this button? I don't see any button at all.
      Has anyone gotten this right?
        After a adding the pre-release to my sources.list. I was able to get the Upgrade tool running, however I get the following:
        Failed to fetch http://wine.budgetdedicated.com/apt/dists/edgy/Release Unable to find expected entry main/binary-amd64/Packages in Meta-index file (malformed Release file?)
        Can anyone tell me why it is trying to fetch package information from wine to begin with? I don't use wine, i don't even have it installed, and I don't want to use it. Why is it forcing wine to be in the repository when I currently do not have it?
          nevermind, I found the winehq.list in /etc/apt/sources.list.d/, removing it, remove the problem.
            This worked for me. I added pre-feisty repository, upgraded, rebooted (don't forget that part, folks), started Adept Manager and clicked on "Fetch updates". After the known message, I clicked on "Finish" and Adept Manager was closed automatically. So was the Upgrade Tool started automatically.
              I have the same issue as you guys, however the steps described did not resolve my problems. Running adept_updater from the command line gives the following output (this log is from the time the wizard runs).
              blake@blake-laptop:~$ sudo adept_updater
              Password:
              DCOPClient::attachInternal. Attach failed Could not open network socket
              Xlib: connection to ":0.0" refused by server
              Xlib: Invalid MIT-MAGIC-COOKIE-1 key
              kdeinit: Can't connect to the X Server.
              kdeinit: Might not terminate at end of session.
              kded: cannot connect to X server :0
              kded: ERROR: KUniqueApplication: Registering failed!
              kded: ERROR: Communication problem with kded, it probably crashed.
              kapture::PkgSystem::PkgSystem()
              libasound2
              libc6
              mpg321
              kio_uiserver: cannot connect to X server :0.0
              ERROR: Communication problem with kio_uiserver, it probably crashed.
              kio_http_debug: WARNING: (5287) Can't communicate with kded_kcookiejar!
              kio (kioslave): WARNING: Can't communicate with kded_kpasswdserver!
              libasound2
              libc6
              mpg321
              gpg: Signature made Tue 17 Apr 2007 07:19:18 AM EST using DSA key ID 437D05B5
              gpg: Good signature from "Ubuntu Archive Automatic Signing Key <ftpmaster@ubuntu.com>"
              gpg: WARNING: This key is not certified with a trusted signature!
              gpg:     There is no indication that the signature belongs to the owner.
              Primary key fingerprint: 6302 39CC 130E 1A7F D81A 27B1 4097 6EAF 437D 05B5
              can't load DistUpgradeViewKDE (/usr/lib/python2.4/site-packages/kparts.so: undefined symbol: _ZN11konsolePart8setPtyFdEi)
              /var/lib/python-support/python2.4/gtk-2.0/gtk/__init__.py:69: GtkWarning: could not open display
               warnings.warn(str(e), _gtk.Warning)
              can't load DistUpgradeViewGtk (No module named UpdateManager.Common.SimpleGladeApp)
              Reading cache
              Checking package manager
              Reading package lists: Done
              Reading state information: Done
              Done [url]http://au.archive.ubuntu.com[/url] edgy Release.gpg
              <snipped much updating of edgy>
              Hit [url]http://archive.ubuntu.com[/url] edgy/multiverse Packages
              Done downloading
              Updating repository information
              WARNING: Failed to read mirror file
              Done [url]http://au.archive.ubuntu.com[/url] feisty Release.gpg
              Ignored [url]http://au.archive.ubuntu.com[/url] feisty/main Translation-en_US
              Failed [url]http://au.archive.ubuntu.com[/url] feisty/main Translation-en_US
              Ignored [url]http://au.archive.ubuntu.com[/url] feisty/restricted Translation-en_US
              Failed [url]http://au.archive.ubuntu.com[/url] feisty/restricted Translation-en_US
              Ignored [url]http://au.archive.ubuntu.com[/url] feisty/universe Translation-en_US
              Failed [url]http://au.archive.ubuntu.com[/url] feisty/universe Translation-en_US
              Done [url]http://au.archive.ubuntu.com[/url] feisty-updates Release.gpg
              Ignored [url]http://au.archive.ubuntu.com[/url] feisty-updates/main Translation-en_US
              Failed [url]http://au.archive.ubuntu.com[/url] feisty-updates/main Translation-en_US
              Ignored [url]http://au.archive.ubuntu.com[/url] feisty-updates/restricted Translation-en_US
              Failed [url]http://au.archive.ubuntu.com[/url] feisty-updates/restricted Translation-en_US
              Done [url]http://security.ubuntu.com[/url] feisty-security Release.gpg
              Ignored [url]http://security.ubuntu.com[/url] feisty-security/main Translation-en_US
              Failed [url]http://security.ubuntu.com[/url] feisty-security/main Translation-en_US
              Ignored [url]http://security.ubuntu.com[/url] feisty-security/restricted Translation-en_US
              Failed [url]http://security.ubuntu.com[/url] feisty-security/restricted Translation-en_US
              Done [url]http://archive.canonical.com[/url] feisty-commercial Release.gpg
              Ignored [url]http://archive.canonical.com[/url] feisty-commercial/main Translation-en_US
              Failed [url]http://archive.canonical.com[/url] feisty-commercial/main Translation-en_US
              Done [url]http://archive.ubuntu.com[/url] feisty-backports Release.gpg
              Ignored [url]http://archive.ubuntu.com[/url] feisty-backports/main Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty-backports/main Translation-en_US
              Ignored [url]http://archive.ubuntu.com[/url] feisty-backports/restricted Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty-backports/restricted Translation-en_US
              Ignored [url]http://security.ubuntu.com[/url] feisty-security/universe Translation-en_US
              Failed [url]http://security.ubuntu.com[/url] feisty-security/universe Translation-en_US
              Ignored [url]http://archive.ubuntu.com[/url] feisty-backports/universe Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty-backports/universe Translation-en_US
              Ignored [url]http://archive.ubuntu.com[/url] feisty-backports/multiverse Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty-backports/multiverse Translation-en_US
              Done [url]http://archive.ubuntu.com[/url] feisty-updates Release.gpg
              Ignored [url]http://archive.ubuntu.com[/url] feisty-updates/main Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty-updates/main Translation-en_US
              Ignored [url]http://archive.ubuntu.com[/url] feisty-updates/restricted Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty-updates/restricted Translation-en_US
              Ignored [url]http://archive.ubuntu.com[/url] feisty-updates/universe Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty-updates/universe Translation-en_US
              Ignored [url]http://archive.ubuntu.com[/url] feisty-updates/multiverse Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty-updates/multiverse Translation-en_US
              Done [url]http://archive.ubuntu.com[/url] feisty-security Release.gpg
              Ignored [url]http://archive.ubuntu.com[/url] feisty-security/main Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty-security/main Translation-en_US
              Ignored [url]http://archive.ubuntu.com[/url] feisty-security/restricted Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty-security/restricted Translation-en_US
              Ignored [url]http://archive.ubuntu.com[/url] feisty-security/universe Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty-security/universe Translation-en_US
              Ignored [url]http://archive.ubuntu.com[/url] feisty-security/multiverse Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty-security/multiverse Translation-en_US
              Done [url]http://archive.ubuntu.com[/url] feisty Release.gpg
              Ignored [url]http://archive.ubuntu.com[/url] feisty/main Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty/main Translation-en_US
              Ignored [url]http://archive.ubuntu.com[/url] feisty/restricted Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty/restricted Translation-en_US
              Ignored [url]http://archive.ubuntu.com[/url] feisty/universe Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty/universe Translation-en_US
              Ignored [url]http://archive.ubuntu.com[/url] feisty/multiverse Translation-en_US
              Failed [url]http://archive.ubuntu.com[/url] feisty/multiverse Translation-en_US
              Done [url]http://archive.canonical.com[/url] feisty-commercial/main Packages
              Done [url]http://security.ubuntu.com[/url] feisty-security/main Packages
              Done [url]http://security.ubuntu.com[/url] feisty-security/restricted Packages
              Done [url]http://security.ubuntu.com[/url] feisty-security/main Sources
              Done [url]http://security.ubuntu.com[/url] feisty-security/restricted Sources
              Done [url]http://security.ubuntu.com[/url] feisty-security/universe Packages
              Done [url]http://archive.ubuntu.com[/url] feisty-backports/main Packages
              Done [url]http://archive.ubuntu.com[/url] feisty-backports/restricted Packages
              Done [url]http://archive.ubuntu.com[/url] feisty-backports/universe Packages
              Done [url]http://archive.ubuntu.com[/url] feisty-backports/multiverse Packages
              Done [url]http://archive.ubuntu.com[/url] feisty-updates/main Packages
              Done [url]http://archive.ubuntu.com[/url] feisty-updates/restricted Packages
              Done [url]http://archive.ubuntu.com[/url] feisty-updates/universe Packages
              Done [url]http://archive.ubuntu.com[/url] feisty-updates/multiverse Packages
              Done [url]http://archive.ubuntu.com[/url] feisty-security/main Packages
              Done [url]http://archive.ubuntu.com[/url] feisty-security/restricted Packages
              Done [url]http://archive.ubuntu.com[/url] feisty-security/universe Packages
              Done [url]http://archive.ubuntu.com[/url] feisty-security/multiverse Packages
              Done [url]http://au.archive.ubuntu.com[/url] feisty/main Packages
              Done [url]http://au.archive.ubuntu.com[/url] feisty/restricted Packages
              Done [url]http://au.archive.ubuntu.com[/url] feisty/main Sources
              Done [url]http://au.archive.ubuntu.com[/url] feisty/restricted Sources
              Done [url]http://archive.ubuntu.com[/url] feisty/main Packages~^[[6~^[[6~
              Done [url]http://archive.ubuntu.com[/url] feisty/restricted Packages
              Done [url]http://au.archive.ubuntu.com[/url] feisty/universe Packages
              Done [url]http://au.archive.ubuntu.com[/url] feisty/universe Sources
              Done [url]http://au.archive.ubuntu.com[/url] feisty-updates/main Packages
              Done [url]http://au.archive.ubuntu.com[/url] feisty-updates/restricted Packages
              Done [url]http://au.archive.ubuntu.com[/url] feisty-updates/main Sources
              Done [url]http://au.archive.ubuntu.com[/url] feisty-updates/restricted Sources
              Done [url]http://archive.ubuntu.com[/url] feisty/universe Packages
              Done [url]http://archive.ubuntu.com[/url] feisty/multiverse Packages
              Done downloading
              Reading package lists: Doneeisty/multiverse Packages: 95 ges: 47
              Asking for confirmation
              Do you want to start the upgrade?
              5 packages are going to be removed. 115 new packages are going to be installed. 1439 packages are going to be upgraded.
              You have to download a total of 553M. This download will take about 1 hours 10 minutes with a 1Mbit DSL connection and about 21 hours 25 minutes with a 56k modem.
              Fetching and installing the upgrade can take several hours and cannot be canceled at any time later.
              any ideas?
              Cheers
              Blake
