Currently running vista ultimate 64bit 6.0.6000 RTM build. and well looking for something new. Used knoppix a lot in the past for wifi capabilies. I have downloaded kubuntu and ubuntu 6.10 32 and 64bit and did the boot from cd method and seletected the first open to start the os or install the os. then it would start the loading screen and then either the computer would stop doing anything first or the cd would just stop spinning and the loading bar would stop.
AMD x2 4800 939 socket
sapphire radeon x1900xtx
2gb of ddr400 pc3200 dual channel
1 sata1 160gb hd
1 sata2 160gb hd
sound blaster xfi platinum soundcard.
1 sata1 160gb hd
1 sata2 160gb hd
