[SOLVED]Sound problem - almost fixed
    I'm [still] trying to make my SoundBlaster Audigy 2 ZS Platinum work. Under kmix, I can select it and set its volume levels and such but I believe the problem actually lies with the alsa drivers / mixer. It keeps trying to use the on-board soundcard of the motherboard instead of my audigy2.
    When I type
    cat /proc/asound/modules
    I get
     0 snd_via82xx
     1 snd_emu10k1
    I'm guessing the emu10k1 is the audigy 2.
    My "aplay -l" returns what is at the bottom of this post and attached is the alsa-base file. Any ideas?
    aplay -l
    **** List of PLAYBACK Hardware Devices ****
    card 0: V8237 [VIA 8237], device 0: VIA 8237 [VIA 8237]
     Subdevices: 3/4
     Subdevice #0: subdevice #0
     Subdevice #1: subdevice #1
     Subdevice #2: subdevice #2
     Subdevice #3: subdevice #3
    card 0: V8237 [VIA 8237], device 1: VIA 8237 [VIA 8237]
     Subdevices: 1/1
    card 1: Audigy2 [Audigy 2 Platinum [SB0240P]], device 0: emu10k1 [ADC Capture/Standard PCM Playback]
     Subdevices: 32/32
     Subdevice #4: subdevice #4
     Subdevice #5: subdevice #5
     Subdevice #6: subdevice #6
     Subdevice #7: subdevice #7
     Subdevice #8: subdevice #8
     Subdevice #9: subdevice #9
     Subdevice #10: subdevice #10
     Subdevice #11: subdevice #11
     Subdevice #12: subdevice #12
     Subdevice #13: subdevice #13
     Subdevice #14: subdevice #14
     Subdevice #15: subdevice #15
     Subdevice #16: subdevice #16
     Subdevice #17: subdevice #17
     Subdevice #18: subdevice #18
     Subdevice #19: subdevice #19
     Subdevice #20: subdevice #20
     Subdevice #21: subdevice #21
     Subdevice #22: subdevice #22
     Subdevice #23: subdevice #23
     Subdevice #24: subdevice #24
     Subdevice #25: subdevice #25
     Subdevice #26: subdevice #26
     Subdevice #27: subdevice #27
     Subdevice #28: subdevice #28
     Subdevice #29: subdevice #29
     Subdevice #30: subdevice #30
     Subdevice #31: subdevice #31
    card 1: Audigy2 [Audigy 2 Platinum [SB0240P]], device 2: emu10k1 efx [Multichannel Capture/PT Playback]
     Subdevices: 8/8
    card 1: Audigy2 [Audigy 2 Platinum [SB0240P]], device 3: emu10k1 [Multichannel Playback]
     Subdevices: 1/1
    card 1: Audigy2 [Audigy 2 Platinum [SB0240P]], device 4: p16v [p16v]
     Subdevices: 1/1
    Re: Sound problem - almost fixed
    Does your BIOS allow you to disable the onboard chip?
      It sure does.
      That was it! Thanks.
      Meanwhile, I coulda sworn I had done that when I had installed my soundcard into Windows... but oh well. It's done now.
