Hello everybody,
I am trying to configure my ethernet connection at work. They provide me a IP, netmask, gateway and DNS addresses, so I cannot use DHCP.
I have tried configuring the connection using the network using K->System Settings->Network Settings.
I entered everything and it worked great. However, two days ago, I had internet installed at home and tried to connect to the wifi. It did not work (it could be the subject of a future post), and since then it seems that my ethernet connection is not working either (I had to put back all the addresses). When I ping www.google.com or my gateway, it manages to send packets, but 100% of the packets received are lost.
Any solution?
Nicolas
Any solution?
Nicolas
