My System:
Kubuntu 6.06 Dapper
Compaq V5105 (AMD 3300+)
Network controller: Broadcom Corporation BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller (rev 02) 000:06:02.0 0280: 14e4:4318 (rev 02)
Hey this is just an FYI of what worked for me!
I did end up using the latest version of "ndiswrapper" (however any version will probably work).
And thanks for the drivers comwiz18! I got several copies to load appropriately. From both here and here
But after installing ndiswrapper. And running...
sudo rmmod bcm43xx
ndiswrapper -i (your driver)
modprobe ndiswrapper
(“lsmod” verified ndiswrapper loaded)
Nothing seemed to work. I even tried your script here.
I could see my wireless network card using KDE Network-Manager when I used/found an appropriate driver with ndiswrapper. But connecting/activating it always caused the system to hang! For a week I couldn't figure things out!
Then one day (after I had gotten ndiswrapper driver loaded) I pushed that damn little "wireless antenna" button on top of my keyboard (windows activates this feature upon bootup). Every post I read said that in Linux those buttons didn't matter. But as soon as I pushed mine after loading the ndiswrapper driver module...
Whalla!!! Everything works perfect! I have 54/Mb connection (or so my system says). I can browse all wireless networks with KDE Wireless Assistant, and everthing works perfectly!
Hmm...I wonder how many other people have made this mistake with their systems?...
Kubuntu 6.06 Dapper
sudo rmmod bcm43xx
