Hi.
I have received my Kubuntu 6.06 LTS cd yesterday and proceeded
to install it. After some problems at the "APT configuration", it finally installed.
Upon rebooting, i found out some oddities.
1) the Konqueror browser would not browse any other website but google.
Every other webpage refuses to load, even after using every possible proxy
setting, with the right address. The google search results however, show.
So google works, nothing else.
2) Using the irc-client, I could connect to exactly one irc-server without problem,
a private one. Connections to freenode would go through from time to time,
but once the motd showed up, it would freeze and the lag-meter would increase untill ping timeout. When reconnected, it would repeat that behaviour.
3) upon ssh'ing to another shell, the terminal would freeze even after a simple "ps aux" or invoking an irc session from the remote server.
It would not respond anymore, not even to CTRL-commands once it froze.
The ping tool worked fine on all those servers, /etc/resolv.conf looks correct,
so does the network settings that were showed.
So basically: I can only browse to google.com, and can only reach the MOTD
of irc-servers before network latency builds up and my connection to them
freezes.
I am using a cable modem (which supports 4 ip addresses) through a small
hub (or whatever that thing is called that splits the cable modem to different
connections).
Note that the network under XP (which is dual-booted) works flawlessly.
Has anyone some input to share with me, or suggestions ?
I would appreciate it a lot, Kubuntu looks like the perfect alternative for XP.
-Angelo
freezes.
connections).
-Angelo
