Hey.
I just downloaded Kubuntu, i am typing this post from the Live CD now, but the problem is, when i try to install it, everything goes well up to scanning the partitions, and then the installer crashes. I also went into K menu, System and launched QTParted, and then clicked on the HDD, /dec/hdb, then it came up with getting info about partitions or something like that, and i think when it got to /dec/hdb7, QTParted also crashes and exits
I am going to Dual boot with windows XP, but i don't thing this is the problem, Windows XP is on the C: Primary partition, the Swap space will be on a 667Mb partition that is also a primary partition, and there is about 14gb of free space that will be the partition for linux, the partition linux will be installed on is a Logical Partition.
Thanks
Will T
Thanks
Will T
