Problems storing system settings
    Hi!
    I just installed Kubuntu 6.06.1 Desktop on my PC today. Mostly everything worked fine. One thing though is that I can't seem to get my system settings stored (the settings I change manually). My screen resolution defaulted to 800x600 after installation, but as I'm using an 19 inch wide tft screen that normally defaults to 1440x900@60Hz it's not exactly as I want it. I try to set the correct graphics adapter and the correct screen type, but when doing this (and entering administrative mode) I can't save those settings (the Apply button doesn't work). It seems as if I do not get into the administrative mode even though the system says that I am.
    Thanx!
    // Jonas
    System overview:
    ASUS A7N8X Deluxe motherboard
    AMD Athlon XP CPU (2 GHz)
    768 MB RAM
    Seagate SATA 200 GB HD (non dual boot)
    MSI MS8912 nVidia GeForce FX 5600 128 MB graphics card
    Viewsonic 19 inch wide TFT screen VA1912w
    Re: Problems storing system settings
    did you install and run automatix to get the nvdriver? I have AMD athlon 64 with msi mobo and nvidia ge force graphics card and all is well.
    I tried Enlightenment once, it was pretty cool.
      I also have the same problem, many other settings aren't saved such as time to shut down the monitor, etc
      Have you fixed your problem?
