Display power management cause kubuntu not able to boot
    I was trying to setup the display power magement in System Settings then restart the computer.
    After that, I can't boot kubuntu. Any ideas where is the configuration file so that I can re-configure manually via console?
    Thanks
    Re: Display power management cause kubuntu not able to boot
    Have you tried to boot with noapic noacpi noapm as additional parameters? Hopefully this will keep power management "down and out" ...
    HTH
    Birdy
      I did
      " depkg-reconfigure -phigh serverx-xorg
      as mention in xorg.conf and everything works again. is it means the problem lies on the xorg.conf?
      solved
      thanks
