3 Weeks ago I updated from 5.10 to 6.06 dapper drake. All went well until recently. I have a duel boot setup as I am trying to learn Linux.
I am running an Win XP home/Kubuntu/kde 6.06.
My issues is this. I have a PS2 keyboard that does not work in the HP splash screen nor does it work in the Grub boot menu. Once I get to the point where I get my Kubuntu user name and password screen my ps2 keyboard works. This is not a hardware issue. I checked all the connections and I am typeing "now" with my ps2 keyboard. Something else is the issue.
My first step to fix the problem was to use the Synaptic Manager to try to re-install Grub. That did not work. I am now looking for some advise on how to fix the issue?
9-20-2006
Lastnight after I wrote this post I did an update to 6.15 and now upon bootup all I see is a black screen and a command prompt with wired symbols. My keyboard will not work at all. I tried to pop in my System Commander CD and I got Vcom boot menu screen but the only keys that would work on my Keybaord was the Page up and down arrow keys. I need some help. I like linux and I want to contenue learning but this is so frustrating!
9-20-2006
