[c] Installation Problems
    Ok, so I resized my NTFS partition to make room for Linux. I made 11GB of free space. How do I use this free space? It says it's unusable. What do I do from here?
    Re: [c] Installation Problems
    "It says it's unusable"... Windoze, Linux ??
    Tell the partitioner to use the free space available. Select ext3 for filesystem.
      You mean use the largest continuous free space possible option? It then says unusuable free space. The installer sucks.
        What did you use to resize the ntfs partition?
        don
