Infinite loop while detecting/mouting problem.
    Specs:
    Elitegroup KN3 Sli2 Motherboard
    AMD 64 Sempron 3000+ AM2
    2 gigs of ram
    IMB 42.9 GB IDE HDD w/ NTFS
    WDC 74.5 GB IDE HDD w/ NTFS
    64-bit Kubuntu v6.06 booted from CD
    32-bit Windows XP on WDC HDD
    The BIOS starts up fine, the HDDs are both detected properly, and WinXP mounts the drives properly. When I start up the CD, the OS loads. Upon running the installation program, I can make it to "step 5 of 6" where the installer detects disk drives. There it sits and eats up cycles. I've waited over half an hour for it to retry or fail, and ostensibly does neither.
    fdisk does not function, as the drives are never detected.
    mount does not function either.
    Is this a common problem?
