My problem is this: I used to have Kubuntu 6.6 on my computer working perfectly, but I wiped it off, installed Ubuntu, then I wanted to revert back to Kubuntu. I Installed Kubuntu 6.06.1 LTS and when I strated up my computer the Display Module in System settings didn't load, it gave me an error message instead. Afterwards I tried reformatting, repartitioning, but no result.
The error message talks about old setting modules (or something like that, it's in Hungarian) that prevent the new one from running.
Then I created a separate partition on my Windows computer to give it a try (that computer never had any kind of Linux on it), I installed Kubuntu 6.06 (the older one) and I got the same problem with the Display Module. I did not install any updates.
Can you help me?
Can you help me?
