Sound problem SB Audigy LS
    I seem to be having some sort of conflict happening between my Soundblaster Audigy LS and my Motherboard's onboard sound.
    My motherboard is a P4S800D and comes with an ADI AD1980 SoundMAX onboard sound system - which uses the AC97 driver.
    I have disabled it in BIOS (I think), but the mixer still shows my input as using AC97, which it should not considering that I am using the Soundblaster as my sound card. I think this might be to blame for long term sound problems with Linux, one of which involves getting sound to work on Ventrilo (through Cedega) and other sound lag issues.
    Re: Sound problem SB Audigy LS
    I had this same issue with my mobo till I disabled it in the bios and then it stopped showing up in my mixer tab... I used to get this gosh aweful soundwhen AC97 driver was enabled in the bios.. Also check if you have PCI Sound enabled..
