Sound problem with Dapper Drake 6.0.6
    Hey, I'm pretty new to linux and have been trying to figure my way out and around.  Things have been going pretty smoothly and I'm ready to ditch windows all together except for one small problem.  When I first installed my sound worked fine, but then when I went to play some of my mp3's the first one played fine till about halfway through it and then it all of the sudden it stopped working.  Whenever I open up Beep Media Player it tells me something else has locked my soundcard.  I've done a few tests from different sources that I have found to check out my sound card.  I really don't know what any of it means except on lspci -v it tells me that the sound card is available only to root.
    So, the question I have is how do I make it available to all users, and if there is another problem how do I fix that?
    lspci -v
    0000:00:1f.5 Multimedia audio controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller (rev 02)
            Subsystem: Micro-Star International Co., Ltd. 865PE Neo2 (MS-6728)
            Flags: bus master, medium devsel, latency 0, IRQ 201
            I/O ports at dc00 [size=256]
            I/O ports at d800 [size=64]
            Memory at febffa00 (32-bit, non-prefetchable) [size=512]
            Memory at febff900 (32-bit, non-prefetchable) [size=256]
            Capabilities: <available only to root>
    aplay -l
    **** List of PLAYBACK Hardware Devices ****
    card 0: ICH5 [Intel ICH5], device 0: Intel ICH [Intel ICH5]
      Subdevices: 1/1
      Subdevice #0: subdevice #0
    card 0: ICH5 [Intel ICH5], device 4: Intel ICH - IEC958 [Intel ICH5 - IEC958]
      Subdevices: 1/1
    lsmod | grep snd
    snd_intel8x0           33692  2
    snd_ac97_codec         92704  1 snd_intel8x0
    snd_ac97_bus            2304  1 snd_ac97_codec
    snd_pcm_oss            53664  0
    snd_mixer_oss          18688  2 snd_pcm_oss
    snd_pcm                89864  3 snd_intel8x0,snd_ac97_codec,snd_pcm_oss
    snd_timer              25220  1 snd_pcm
    snd                    55268  8 snd_intel8x0,snd_ac97_codec,snd_pcm_oss,snd_mixer_ oss,snd_pcm,snd_timer
    soundcore              10208  2 snd
    snd_page_alloc         10632  2 snd_intel8x0,snd_pcm
    ./aadebug
    ALSA Audio Debug v0.1.0 - Fri Jun 23 09:24:30 EDT 2006
    http://alsa.opensrc.org/index.php?page=aadebug
    http://www.gnu.org/licenses/gpl.txt
    Kernel ----------------------------------------------------
    Linux Mirax 2.6.15-25-386 #1 PREEMPT Wed Jun 14 11:25:49 UTC 2006 i686 GNU/Linux
    Loaded Modules --------------------------------------------
    snd_pcm_oss            53664  0
    Modprobe Conf ---------------------------------------------
    Warning: module config file does not exist
    This means any kernel modules will not be auto loaded
    See your linux distro docs on how to create this file
    Proc Asound -----------------------------------------------
    Advanced Linux Sound Architecture Driver Version 1.0.10rc3 (Mon Nov 07 13:30:21 2005 UTC).
    0 [ICH5           ]: ICH4 - Intel ICH5
                         Intel ICH5 with CMI9739 at 0xfebffa00, irq 201
    20: [0- 4]: digital audio playback
    27: [0- 3]: digital audio capture
    26: [0- 2]: digital audio capture
    25: [0- 1]: digital audio capture
    16: [0- 0]: digital audio playback
    24: [0- 0]: digital audio capture
      0: [0- 0]: ctl
    33:       : timer
    cat: /proc/asound/hwdep: No such file or directory
    00-00: Intel ICH : Intel ICH5 : playback 1 : capture 1
    00-01: Intel ICH - MIC ADC : Intel ICH5 - MIC ADC : capture 1
    00-02: Intel ICH - MIC2 ADC : Intel ICH5 - MIC2 ADC : capture 1
    00-03: Intel ICH - ADC2 : Intel ICH5 - ADC2 : capture 1
    00-04: Intel ICH - IEC958 : Intel ICH5 - IEC958 : playback 1
    cat: /proc/asound/seq/clients: No such file or directory
    Dev Snd ---------------------------------------------------
    controlC0  pcmC0D0c  pcmC0D0p  pcmC0D1c  pcmC0D2c  pcmC0D3c  pcmC0D4p  timer
    CPU -------------------------------------------------------
    model name      : Intel(R) Pentium(R) 4 CPU 2.40GHz
    cpu MHz         : 2400.312
    RAM -------------------------------------------------------
    MemTotal:      1036096 kB
    SwapTotal:     2032180 kB
    Hardware --------------------------------------------------
    0000:00:00.0 Host bridge: Intel Corporation 82865G/PE/P DRAM Controller/Host-Hub Interface (rev 02)
    Re: Sound problem with Dapper Drake 6.0.6
    give this a shot and report back:
    http://www.linuxquestions.org/linux/...dware_debuging
      Thank you very much. It took a little bit of tweaking, but the link you gave me helped me solve my problems. Now everything is up and running perfectly
