I have this problem: I've set up a script to run on logout, and the script doesn't run.
The script is supposed to solve this problem: On shutdown, I get the message: "A stop job is running for session <number> of user <name>". This takes 90 seconds to time out, and I have no option of killing it. I don't want shutdown to take an extra 90 seconds.
This appears to be caused by ProtonVPN. If I disconnect from ProtonVPN before shutting down, the problem is gone:
NB: I have added this application to my sudoers so I can sudo it without having to enter my password. This works fine for my startup script, at least.
What I want to do: Set up a script that disconnects from VPN (by running sudo protonvpn d) automatically upon logout.
So I've written a script containing this (and nothing else):
I pipe the output into a file purely in order to verify that the script gets run. I've set execution permissions on the script file so it can run:
I can run the script manually from the command line and it generates the file ~/protonvpn.txt.
I've set up the script in System Settings -> Starup and Shutdown -> Autostart to run on logout. A symlink to the script appears in ~/.config/plasma-workspace/shutdown/. But when I log out, the file ~/protonvpn.txt does not get generated. And if I shut down while having VPN connected, I still get the 90 second timeout.
My problem looks closely connected to this other problem I had. I was able to fix that by fixing the script itself. But my script here looks completely trivial and works fine when run on its own.
Am I doing something wrong? Why is my script not running?
Thanks in advance!
$ sudo protonvpn d
sudo protonvpn d > ~/protonvpn.txt
-rwxrwxr-x 1 spectrum spectrum 35 Sep 24 18:48 shutdown.sh*
Thanks in advance!
