Hi everyone,
long story short, I've installed Kubuntu 19.04 and almost everything worked out of the box except for the volume controls. Even the sound is working pretty fine both headphone (p2 jack) and speakers but when I try to turn the volume up/down or even mute nothing happens, no OSD, no volume changing. I will list some info below so if you guys can help me fix that I would appreciate.
Some "facts" below:
- plasma-pa is installed
- Shortcuts are configured
https://imgur.com/a/5rVTDPv
- Xev output
- Hard info
https://imgur.com/a/69ggj0J
Some "facts" below:
bruno@funnie:~/.local/share/applications$ dpkg -s plasma-paPackage: plasma-pa
Status: install ok installed
Priority: optional
Section: kde
Installed-Size: 1092
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Architecture: amd64
Version: 4:5.15.4-0ubuntu1
Priority: optional
Section: kde
Architecture: amd64
- Xev output
KeyRelease event, serial 40, synthetic NO, window 0x6600001, root 0x179, subw 0x0, time 33191098, (-448,444), root
688,473),
state 0x0, keycode 121 (keysym 0x1008ff12, XF86AudioMute), same_screen YES,
XLookupString gives 0 bytes:
XFilterEvent returns: False
root 0x179, subw 0x0, time 33191689, (-448,444), root
688,473),
state 0x0, keycode 122 (keysym 0x1008ff11, XF86AudioLowerVolume), same_screen YES,
KeyPress event, serial 40, synthetic NO, window 0x6600001,
root 0x179, subw 0x0, time 33192215, (-448,444), root
688,473),
state 0x0, keycode 123 (keysym 0x1008ff13, XF86AudioRaiseVolume), same_screen YES,
XmbLookupString gives 0 bytes:
