Long time now, Bionic Beaver running just fine, no problems at all.
Then suddenly, I cannot boort without using the "Advanced" option.
If I boot the normal way, I get (and I have to retranslate this from Norwegian, so bear with me ...
Error: Did not find the file 4.15.0-58-generic
Error: You have to read in the kernel first
I am using the "Grub Customizer" utility to get the start priority (Dual boot with WIN10) as I want it.
I heve tried (in Grub Customizer) to use the "install to MBR" option, ands the "Save" option. No change.
So, while I can live with the "Advanced" option for booting - it is about the elegance and things working like they should do. Anyone can help me to sort this out?
