After installing Kubuntu 18.04 on my Fujitsu AH532 I have had problems with controlling the brightness of the display. Initially I had no brightness controls at all after installation. I edited /etc/default/grub and changed the line which read GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" to GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor". Now I have brightness controls again in "Battery and Brightness" and I can also control it with my function keys F6 and F7.
However there is still strange behaviour. If I put the slider up to 100% it is not very bright, it's actually maybe 70%. But if I adjust the slider down, as expected it gets dimmer, and as I reach about 10% the screen is completely dark. However when I reach 0% the screen is suddenly at full brightness!
What can I do to make the brightness slider (or the function keys) operate as they should? Thanks in advance for any suggestions.
