Hey there!
Yesterday I tried to get audio from my second monitor into Kubuntu through the line-in stereo jack which is now basically working after fiddling with "alsamixer" (un-mute Line & getting volume settings right) and adding "load-module module-loopback" to my "/etc/pulse/default.pa"
My current and biggest problem with this setup is the crackling sound / noise I get while playing audio - even after adjusting the line-in volume to ~5% (everything above that is just painful) and increasing volume on my external amplifier. (Under Windows 10 I have no crackling / sound problems with this setup)
What I've tried so far:
1) Having "load-module module-udev-detect tsched=0" (adding the "tsched=0")
in /etc/pulse/default.pa for deactivating timer-based scheduling in PulseAudio which helped other people with crackling sound.
2) Combining 1) with modifications in /etc/pulse/daemon.conf for setting the default fragment number and buffer size in PulseAudio (like here: https://wiki.archlinux.org/index.php/PulseAudio/Troubleshooting#Static_noise_when_using_headphones)
3) Explicitly writing the loopback source & sink with its rate and channels:
And 4) modifying /etc/modprobe.d/alsa-base.conf with "options snd-hda-intel position_fix=1" or "options snd-hda-intel position_fix=2" which was suggested here: [https://wiki.ubuntu.com/Audio/PositionReporting][2]
My system:
My basic audio setup:
Inputs:
- audio coming from second monitor into computer line-in
- all other audio is coming from the system / applications / music
Output:
- USB-DAC/AMP which my headphone is connected to
I hope you can help or give me some pointers to where I could find an answer
Thank you for your time and have a nice week!
Greetings!
load-module module-loopback source=alsa_input.pci-0000_12_00.3.analog-stereo sink=alsa_output.usb-FiiO_DigiHug_USB_Audio-01.analog-stereo rate=44100 channels=2
My system:
[FONT=monospace]inxi -Fxz [/FONT][FONT=monospace][COLOR=#5454FF][B]System: [/B][/COLOR][COLOR=#5454FF][B]Host:[/B][/COLOR][COLOR=#B2B2B2] NX-Vorkangtonix [/COLOR][COLOR=#5454FF][B]Kernel:[/B][/COLOR][COLOR=#B2B2B2] 4.13.0-36-generic x86_64 [/COLOR][COLOR=#5454FF][B]bits:[/B][/COLOR][COLOR=#B2B2B2] 64 [/COLOR][COLOR=#5454FF][B]gcc:[/B][/COLOR][COLOR=#B2B2B2] 7.2.0[/COLOR] [COLOR=#5454FF][B]Desktop:[/B][/COLOR][COLOR=#B2B2B2] KDE Plasma 5.12.3 (Qt 5.9.1) [/COLOR][COLOR=#5454FF][B]Distro:[/B][/COLOR][COLOR=#B2B2B2] Ubuntu 17.10 [/COLOR] [COLOR=#5454FF][B]Machine: [/B][/COLOR][COLOR=#5454FF][B]Device:[/B][/COLOR][COLOR=#B2B2B2] desktop [/COLOR][COLOR=#5454FF][B]Mobo:[/B][/COLOR][COLOR=#B2B2B2] ASRock [/COLOR][COLOR=#5454FF][B]model:[/B][/COLOR][COLOR=#B2B2B2] X370 Taichi [/COLOR][COLOR=#5454FF][B]serial:[/B][/COLOR][COLOR=#B2B2B2] N/A [/COLOR] [COLOR=#5454FF][B]UEFI:[/B][/COLOR][COLOR=#B2B2B2] American Megatrends [/COLOR][COLOR=#5454FF][B]v:[/B][/COLOR][COLOR=#B2B2B2] P3.20 [/COLOR][COLOR=#5454FF][B]date:[/B][/COLOR][COLOR=#B2B2B2] 09/08/2017 [/COLOR] [COLOR=#5454FF][B]CPU: [/B][/COLOR][COLOR=#5454FF][B]Octa core[/B][/COLOR][COLOR=#B2B2B2] AMD Ryzen 7 1700X Eight-Core (-HT-MCP-) [/COLOR][COLOR=#5454FF][B]arch:[/B][/COLOR][COLOR=#B2B2B2] Zen rev.1 [/COLOR][COLOR=#5454FF][B]cache:[/B][/COLOR][COLOR=#B2B2B2] 4096 KB [/COLOR] [COLOR=#5454FF][B]flags:[/B][/COLOR][COLOR=#B2B2B2] (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) [/COLOR][COLOR=#5454FF][B]bmips:[/B][/COLOR][COLOR=#B2B2B2] 54401 [/COLOR] [COLOR=#5454FF][B]clock speeds:[/B][/COLOR][COLOR=#5454FF][B]max:[/B][/COLOR][COLOR=#B2B2B2] 3400 MHz [/COLOR][COLOR=#5454FF][B]1:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR][COLOR=#5454FF][B]2:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR][COLOR=#5454FF][B]3:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR][COLOR=#5454FF][B]4:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR][COLOR=#5454FF][B]5:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR] [COLOR=#5454FF][B]6:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR][COLOR=#5454FF][B]7:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR][COLOR=#5454FF][B]8:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR][COLOR=#5454FF][B]9:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR][COLOR=#5454FF][B]10:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR][COLOR=#5454FF][B]11:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR][COLOR=#5454FF][B]12:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR] [COLOR=#5454FF][B]13:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR][COLOR=#5454FF][B]14:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR][COLOR=#5454FF][B]15:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR][COLOR=#5454FF][B]16:[/B][/COLOR][COLOR=#B2B2B2] 2200 MHz [/COLOR] [COLOR=#5454FF][B]Graphics: [/B][/COLOR][COLOR=#5454FF][B]Card:[/B][/COLOR][COLOR=#B2B2B2] NVIDIA GP104 [GeForce GTX 1070] [/COLOR][COLOR=#5454FF][B]bus-ID:[/B][/COLOR][COLOR=#B2B2B2] 0e:00.0 [/COLOR] [COLOR=#5454FF][B]Display Server:[/B][/COLOR][COLOR=#B2B2B2] x11 (X.Org 1.19.5 ) [/COLOR][COLOR=#5454FF][B]driver:[/B][/COLOR][COLOR=#B2B2B2] nvidia [/COLOR] [COLOR=#5454FF][B]Resolution:[/B][/COLOR][COLOR=#B2B2B2] 1920x1080@60.00hz, 1920x1080@60.00hz [/COLOR] [COLOR=#5454FF][B]OpenGL: renderer:[/B][/COLOR][COLOR=#B2B2B2] GeForce GTX 1070/PCIe/SSE2 [/COLOR][COLOR=#5454FF][B]version:[/B][/COLOR][COLOR=#B2B2B2] 4.5.0 NVIDIA 384.111 [/COLOR][COLOR=#5454FF][B]Direct Render:[/B][/COLOR][COLOR=#B2B2B2] Yes [/COLOR] [COLOR=#5454FF][B]Audio: [/B][/COLOR][COLOR=#5454FF][B]Card-1[/B][/COLOR][COLOR=#B2B2B2] Advanced Micro Devices [AMD] Device 1457 [/COLOR][COLOR=#5454FF][B]driver:[/B][/COLOR][COLOR=#B2B2B2] snd_hda_intel [/COLOR][COLOR=#5454FF][B]bus-ID:[/B][/COLOR][COLOR=#B2B2B2] 12:00.3 [/COLOR] [COLOR=#5454FF][B]Card-2[/B][/COLOR][COLOR=#B2B2B2] NVIDIA GP104 High Def. Audio Controller [/COLOR][COLOR=#5454FF][B]driver:[/B][/COLOR][COLOR=#B2B2B2] snd_hda_intel [/COLOR][COLOR=#5454FF][B]bus-ID:[/B][/COLOR][COLOR=#B2B2B2] 0e:00.1 [/COLOR] [COLOR=#5454FF][B]Card-3[/B][/COLOR][COLOR=#B2B2B2] GYROCOM C&C [/COLOR][COLOR=#5454FF][B]driver:[/B][/COLOR][COLOR=#B2B2B2] USB Audio [/COLOR][COLOR=#5454FF][B]usb-ID:[/B][/COLOR][COLOR=#B2B2B2] 003-004 [/COLOR] [COLOR=#5454FF][B]Sound:[/B][/COLOR][COLOR=#B2B2B2] Advanced Linux Sound Architecture [/COLOR][COLOR=#5454FF][B]v:[/B][/COLOR][COLOR=#B2B2B2] k4.13.0-36-generic [/COLOR] [COLOR=#5454FF][B]Network: [/B][/COLOR][COLOR=#5454FF][B]Card-1:[/B][/COLOR][COLOR=#B2B2B2] Intel Device 24fb [/COLOR][COLOR=#5454FF][B]driver:[/B][/COLOR][COLOR=#B2B2B2] iwlwifi [/COLOR][COLOR=#5454FF][B]bus-ID:[/B][/COLOR][COLOR=#B2B2B2] 09:00.0 [/COLOR] [COLOR=#5454FF][B]IF:[/B][/COLOR][COLOR=#B2B2B2] wlp9s0 [/COLOR][COLOR=#5454FF][B]state:[/B][/COLOR][COLOR=#B2B2B2] down [/COLOR][COLOR=#5454FF][B]mac:[/B][/COLOR][COLOR=#B2B2B2] <filter> [/COLOR] [COLOR=#5454FF][B]Card-2:[/B][/COLOR][COLOR=#B2B2B2] Intel I211 Gigabit Network Connection [/COLOR] [COLOR=#5454FF][B]driver:[/B][/COLOR][COLOR=#B2B2B2] igb [/COLOR][COLOR=#5454FF][B]v:[/B][/COLOR][COLOR=#B2B2B2] 5.4.0-k [/COLOR][COLOR=#5454FF][B]port:[/B][/COLOR][COLOR=#B2B2B2] d000 [/COLOR][COLOR=#5454FF][B]bus-ID:[/B][/COLOR][COLOR=#B2B2B2] 0b:00.0 [/COLOR] [COLOR=#5454FF][B]IF:[/B][/COLOR][COLOR=#B2B2B2] enp11s0 [/COLOR][COLOR=#5454FF][B]state:[/B][/COLOR][COLOR=#B2B2B2] up [/COLOR][COLOR=#5454FF][B]speed:[/B][/COLOR][COLOR=#B2B2B2] 1000 Mbps [/COLOR][COLOR=#5454FF][B]duplex:[/B][/COLOR][COLOR=#B2B2B2] full [/COLOR][COLOR=#5454FF][B]mac:[/B][/COLOR][COLOR=#B2B2B2] <filter> [/COLOR] [COLOR=#5454FF][B]Drives: [/B][/COLOR][COLOR=#5454FF][B]HDD Total Size:[/B][/COLOR][COLOR=#B2B2B2] 4256.9GB (9.1% used) [/COLOR] [COLOR=#5454FF][B]ID-1:[/B][/COLOR][COLOR=#B2B2B2] /dev/nvme0n1 [/COLOR][COLOR=#5454FF][B]model:[/B][/COLOR][COLOR=#B2B2B2] N/A [/COLOR][COLOR=#5454FF][B]size:[/B][/COLOR][COLOR=#B2B2B2] 500.1GB [/COLOR] [COLOR=#5454FF][B]ID-2:[/B][/COLOR][COLOR=#B2B2B2] /dev/sda [/COLOR][COLOR=#5454FF][B]model:[/B][/COLOR][COLOR=#B2B2B2] SAMSUNG_SSD_830 [/COLOR][COLOR=#5454FF][B]size:[/B][/COLOR][COLOR=#B2B2B2] 256.1GB [/COLOR] [COLOR=#5454FF][B]ID-3:[/B][/COLOR][COLOR=#B2B2B2] /dev/sdb [/COLOR][COLOR=#5454FF][B]model:[/B][/COLOR][COLOR=#B2B2B2] WDC_WD20EZRZ [/COLOR][COLOR=#5454FF][B]size:[/B][/COLOR][COLOR=#B2B2B2] 2000.4GB [/COLOR] [COLOR=#5454FF][B]ID-4:[/B][/COLOR][COLOR=#B2B2B2] /dev/sdc [/COLOR][COLOR=#5454FF][B]model:[/B][/COLOR][COLOR=#B2B2B2] WDC_WD20EZRZ [/COLOR][COLOR=#5454FF][B]size:[/B][/COLOR][COLOR=#B2B2B2] 2000.4GB [/COLOR] [COLOR=#5454FF][B]Partition:[/B][/COLOR][COLOR=#5454FF][B]ID-1:[/B][/COLOR][COLOR=#B2B2B2] / [/COLOR][COLOR=#5454FF][B]size:[/B][/COLOR][COLOR=#B2B2B2] 18G [/COLOR][COLOR=#5454FF][B]used:[/B][/COLOR][COLOR=#B2B2B2] 12G (70%) [/COLOR][COLOR=#5454FF][B]fs:[/B][/COLOR][COLOR=#B2B2B2] ext4 [/COLOR][COLOR=#5454FF][B]dev:[/B][/COLOR][COLOR=#B2B2B2] /dev/nvme0n1p5 [/COLOR] [COLOR=#5454FF][B]ID-2:[/B][/COLOR][COLOR=#B2B2B2] /home [/COLOR][COLOR=#5454FF][B]size:[/B][/COLOR][COLOR=#B2B2B2] 122G [/COLOR][COLOR=#5454FF][B]used:[/B][/COLOR][COLOR=#B2B2B2] 25G (22%) [/COLOR][COLOR=#5454FF][B]fs:[/B][/COLOR][COLOR=#B2B2B2] ext4 [/COLOR][COLOR=#5454FF][B]dev:[/B][/COLOR][COLOR=#B2B2B2] /dev/nvme0n1p6 [/COLOR] [COLOR=#5454FF][B]RAID: [/B][/COLOR][COLOR=#B2B2B2] No RAID devices: /proc/mdstat, md_mod kernel module present [/COLOR] [COLOR=#5454FF][B]Sensors: [/B][/COLOR][COLOR=#5454FF][B]System Temperatures: cpu:[/B][/COLOR][COLOR=#B2B2B2] 30.0C [/COLOR][COLOR=#5454FF][B]mobo:[/B][/COLOR][COLOR=#B2B2B2] 32.0C [/COLOR][COLOR=#5454FF][B]gpu:[/B][/COLOR][COLOR=#B2B2B2] 0.0:49C [/COLOR] [COLOR=#5454FF][B]Fan Speeds (in rpm): cpu:[/B][/COLOR][COLOR=#B2B2B2] 5378 [/COLOR][COLOR=#5454FF][B]mobo:[/B][/COLOR][COLOR=#B2B2B2] 5378 [/COLOR][COLOR=#5454FF][B]fan-1:[/B][/COLOR][COLOR=#B2B2B2] 936 [/COLOR][COLOR=#5454FF][B]fan-2:[/B][/COLOR][COLOR=#B2B2B2] 0 [/COLOR][COLOR=#5454FF][B]fan-4:[/B][/COLOR][COLOR=#B2B2B2] 1317 [/COLOR][COLOR=#5454FF][B]fan-5:[/B][/COLOR][COLOR=#B2B2B2] 0 [/COLOR] [COLOR=#5454FF][B]Info: [/B][/COLOR][COLOR=#5454FF][B]Processes:[/B][/COLOR][COLOR=#B2B2B2] 360 [/COLOR][COLOR=#5454FF][B]Uptime:[/B][/COLOR][COLOR=#B2B2B2] 4:17 [/COLOR][COLOR=#5454FF][B]Memory:[/B][/COLOR][COLOR=#B2B2B2] 5986.4/16034.3MB [/COLOR] [COLOR=#5454FF][B]Init:[/B][/COLOR][COLOR=#B2B2B2] systemd [/COLOR][COLOR=#5454FF][B]runlevel:[/B][/COLOR][COLOR=#B2B2B2] 5 [/COLOR][COLOR=#5454FF][B]Gcc sys:[/B][/COLOR][COLOR=#B2B2B2] 7.2.0 [/COLOR][COLOR=#5454FF][B]Client:[/B][/COLOR][COLOR=#B2B2B2] Shell (bash 4.4.121) [/COLOR][COLOR=#5454FF][B]inxi:[/B][/COLOR][COLOR=#B2B2B2] 2.3.37 [/COLOR] [/FONT]
lspci -nnk | grep -i audio -A2 0e:00.1 Audio device [0403]: NVIDIA Corporation GP104 High Definition Audio Controller [10de:10f0] (rev a1) Subsystem: CardExpert Technology GP104 High Definition Audio Controller [10b0:1b81] Kernel driver in use: snd_hda_intel Kernel modules: snd_hda_intel -- 12:00.3 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Device [1022:1457] Subsystem: ASRock Incorporation Device [1849:1220] Kernel driver in use: snd_hda_intel
cat /proc/asound/cards 0 [NVidia ]: HDA-Intel - HDA NVidia HDA NVidia at 0xfd080000 irq 329 1 [Audio ]: USB-Audio - DigiHug USB Audio FiiO DigiHug USB Audio at usb-0000:11:00.3-2, full speed 2 [Generic ]: HDA-Intel - HD-Audio Generic HD-Audio Generic at 0xfd900000 irq 331
pactl list sources Quelle #0 Status: RUNNING Name: alsa_output.usb-FiiO_DigiHug_USB_Audio-01.analog-stereo.monitor Beschreibung: Monitor of DigiHug USB Audio Analog Stereo Treiber: module-alsa-card.c Abtastwert-Angabe: s16le 2ch 44100Hz Kanalzuordnung: front-left,front-right Besitzer-Modul: 7 Stumm: ja Lautstärke: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB Verteilung 0,00 Basis-Lautstärke: 65536 / 100% / 0,00 dB Ziel-Monitor: alsa_output.usb-FiiO_DigiHug_USB_Audio-01.analog-stereo Latenz: 0 usec, eingestellt 40000 usec Flags: DECIBEL_VOLUME LATENCY Eigenschaften: device.description = "Monitor of DigiHug USB Audio Analog Stereo" device.class = "monitor" alsa.card = "1" alsa.card_name = "DigiHug USB Audio" alsa.long_card_name = "FiiO DigiHug USB Audio at usb-0000:11:00.3-2, full speed" alsa.driver_name = "snd_usb_audio" device.bus_path = "pci-0000:11:00.3-usb-0:2:1.1" sysfs.path = "/devices/pci0000:00/0000:00:07.1/0000:11:00.3/usb3/3-2/3-2:1.1/sound/card1" udev.id = "usb-FiiO_DigiHug_USB_Audio-01" device.bus = "usb" device.vendor.id = "1852" device.vendor.name = "GYROCOM C&C Co., LTD" device.product.id = "7022" device.product.name = "DigiHug USB Audio" device.serial = "FiiO_DigiHug_USB_Audio" device.string = "1" module-udev-detect.discovered = "1" device.icon_name = "audio-card-usb" Formate: pcm Quelle #1 Status: RUNNING Name: alsa_input.pci-0000_12_00.3.analog-stereo Beschreibung: HD-Audio Generic Analog Stereo Treiber: module-alsa-card.c Abtastwert-Angabe: s16le 2ch 44100Hz Kanalzuordnung: front-left,front-right Besitzer-Modul: 8 Stumm: nein Lautstärke: front-left: 6554 / 10% / -60,00 dB, front-right: 6554 / 10% / -60,00 dB Verteilung 0,00 Basis-Lautstärke: 6554 / 10% / -60,00 dB Ziel-Monitor: k. A. Latenz: 30 usec, eingestellt 40000 usec Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY Eigenschaften: alsa.resolution_bits = "16" device.api = "alsa" device.class = "sound" alsa.class = "generic" alsa.subclass = "generic-mix" alsa.name = "ALC1220 Analog" alsa.id = "ALC1220 Analog" alsa.subdevice = "0" alsa.subdevice_name = "subdevice #0" alsa.device = "0" alsa.card = "2" alsa.card_name = "HD-Audio Generic" alsa.long_card_name = "HD-Audio Generic at 0xfd900000 irq 331" alsa.driver_name = "snd_hda_intel" device.bus_path = "pci-0000:12:00.3" sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:12:00.3/sound/card2" device.bus = "pci" device.vendor.id = "1022" device.vendor.name = "Advanced Micro Devices, Inc. [AMD]" device.product.id = "1457" device.string = "front:2" device.buffering.buffer_size = "65536" device.buffering.fragment_size = "32768" device.access_mode = "mmap+timer" device.profile.name = "analog-stereo" device.profile.description = "Analog Stereo" device.description = "HD-Audio Generic Analog Stereo" alsa.mixer_name = "Realtek ALC1220" alsa.components = "HDA:10ec1220,18491220,00100003" module-udev-detect.discovered = "1" device.icon_name = "audio-card-pci" Ports: analog-input-front-mic: Vorderes Mikrofon (priority: 8500, not available) analog-input-rear-mic: Rückwärtiges Mikrofon (priority: 8200, not available) analog-input-linein: Eingang (priority: 8100, available) Aktiver Port: analog-input-linein Formate: pcm
pactl list sinks Ziel #0 Status: RUNNING Name: alsa_output.usb-FiiO_DigiHug_USB_Audio-01.analog-stereo Beschreibung: DigiHug USB Audio Analog Stereo Treiber: module-alsa-card.c Abtastwert-Angabe: s16le 2ch 44100Hz Kanalzuordnung: front-left,front-right Besitzer-Modul: 7 Stumm: nein Lautstärke: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB Verteilung 0,00 Basis-Lautstärke: 65536 / 100% / 0,00 dB Quellen-Monitor: alsa_output.usb-FiiO_DigiHug_USB_Audio-01.analog-stereo.monitor Latenz: 46296 usec, eingestellt 40000 usec Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY Eigenschaften: alsa.resolution_bits = "16" device.api = "alsa" device.class = "sound" alsa.class = "generic" alsa.subclass = "generic-mix" alsa.name = "USB Audio" alsa.id = "USB Audio" alsa.subdevice = "0" alsa.subdevice_name = "subdevice #0" alsa.device = "0" alsa.card = "1" alsa.card_name = "DigiHug USB Audio" alsa.long_card_name = "FiiO DigiHug USB Audio at usb-0000:11:00.3-2, full speed" alsa.driver_name = "snd_usb_audio" device.bus_path = "pci-0000:11:00.3-usb-0:2:1.1" sysfs.path = "/devices/pci0000:00/0000:00:07.1/0000:11:00.3/usb3/3-2/3-2:1.1/sound/card1" udev.id = "usb-FiiO_DigiHug_USB_Audio-01" device.bus = "usb" device.vendor.id = "1852" device.vendor.name = "GYROCOM C&C Co., LTD" device.product.id = "7022" device.product.name = "DigiHug USB Audio" device.serial = "FiiO_DigiHug_USB_Audio" device.string = "front:1" device.buffering.buffer_size = "352800" device.buffering.fragment_size = "176400" device.access_mode = "mmap+timer" device.profile.name = "analog-stereo" device.profile.description = "Analog Stereo" device.description = "DigiHug USB Audio Analog Stereo" alsa.mixer_name = "USB Mixer" alsa.components = "USB1852:7022" module-udev-detect.discovered = "1" device.icon_name = "audio-card-usb" Ports: analog-output: Analoge Ausgabe (priority: 9900) Aktiver Port: analog-output Formate: pcm
Inputs:
Output:
Greetings!
