Hi all, long time no speak. Wondering if you can help. Just upgraded my brother's laptop from 14.04 to 16.04. Went the upgrade route rather than clean install. All seemed to go to plan. However selecting the default boot I see the kubuntu logo for a while then I get a black screen. Rebooting and using the grub advanced options if I select the upstart option it boots as normal. Using the recovery mode (which I assume is systemd) if I drop to a root shell and type startx I get to a desktop as root..
Any thoughts on a simple way to fix this please?
