I have installed Kubuntu 16.04 LTS for the fifth titme. I am not well used to command line. I will pick up. I am very happy with the look and feel of the OS. Kubuntu is working stable except one problem. HSPA USB modem. It is Lava 730G. I am staying in a coconut farm 12 KMs from the nearest town. Signal strength outside the house is good, inside it reverts to E. I have used best quality 3 MTrs and 2 MTrs extension cables and hoisted the the dongle up on to ceiling. I can get 4.5 MiB connection this way. Cable length is within limitations so that is not a problem. On installation HSPA modem works fine. Once I switch off the system. I have to change dongle in to some other USB port, otherwise I am not able to connect. I have installed Sakis3G. It fails to do anything other than modem switching. Gives an error after 14% of trying to correct that modem-switch is in control of device and it cannot do anything. I have updated and upgraded as per Sakis3G. 470 MiB download. No use
In another thread I read output of lshw and lspic helps in understanding what is happening. I am attaching a file with output details.
I think this is a bug in the system.
