Teamviewer is excellent, but with one caveat, which doesn't matter if you use it a lot and keep it in your system tray for potential or future logins. However, if you close it and quit it from the system tray its daemon, teamviewerd, will remain as a service. What it is doing when the GUI and system tray icon are closed is any body's guess. If you are concerned you might want to write a small script which disables the daemon when you are finished using it.
It has some problems. The host must open a hole in their firewall for port forwarding on 5900. There is no concurrent audio connection so both parties must use a speaker phone or get creaks in their necks, and no file transfer capability, so other means must be used. No group capability. It works OK on the the same subnet (192.168.*.*) but in my experience it is too slow over the Internet.
TeamViewer, on the other hand, is browser based, is relatively quick, activates both the mic and webcam, if needed, allows simultaneous bi-directional file transfer, and the paid version has a "Hangout" conference capability, but I don't remember the limit on the number of participants.
A great app, but the only thing I don't like is when you shut everything down, including the systray icon, it leaves a daemon in services. Why? Spy? I kill the daemon when I quit the app.
