I installed 16.04 (64bit) 3 days ago. I don't want to move things to Trash. When I try to delete an image in Gwenview, I get the message:
The key sequence 'Shift+Del' is ambiguous. Use 'Configure Shortcuts'
from the 'Settings' menu to solve the ambiguity.
No action will be triggered.
Yet when I look at Shortcuts in System settings, I can find no shift+del defined anywhere. Ditto for Input devices > Keyboard.
Also, I cannot figure out how to define a shortcut in one of those things.
I do not use the same home on my different systems. I have all my files in a subdirectory of my home directory and I diddle firefox, thunderbird and amarok to point to those files. But the other config files are those defined by the install of 16.04.
What can I do?
What can I do?
