Hi together!
When switching the primary screen in the display settings the panels (or just the one panel) often (but not always) appear on the wrong sceen, meaning for the standard panel the other screen than which is selected as primary. Even worse, if one screen gets deactivated in the display settings often the panel disappears completely. (This leads to the assumption that, then again, the panel moves to the wrong screen, in this case meaning the deactivated one.)
When applying changes often the panel flickers once oder a few times back and forth between the two screens as if there were things fighting against each other. Also, after making switches in the display settings things like the kde menu or some dropdown menus appear on the other screen (and then, of course, disconnected from their actual position).
It’s a general problem in Kubuntu 16.04. I’ve tried on different machines, even with different graphic drivers.
This issue might or might not be related to https://blog.martin-graesslin.com/bl...y-of-plasma-5/ (see "Multi screen woes" there). So it could be a problem with Qt, actually?
Anyway, is there a solution for that? Thanks for help!
