As the title says Kmail does not launch after upgrading to Kubuntu 16.04. I did an online upgrade from 64 bit 15.10. Now, when I either click on the kmail desktop icon or menu selection, nothing seems to happen. I tried launching it from a terminal, and again nothing seemed to happen, and there were no error messages. Has anyone else had this happen or have any idea what's going on?
Kmail not launching after 64-bit 16.04 upgrade
"solution"
The same happened to me, after having done the same update from 15.10 to 16.04 today. I created a new user account to check if it was a generic problem of my installation, but for that user kmail works fine. So I suspect there is something wrong with upgrading the data format.
Then I noticed that a kmail process was running invisibly ($pgrep kmail). So I tried the following, and it helped. I can not tell whether all of it was required.
Code:akonadictl stop pkill kmail akonadictl start kmail
Hi
Please, look at this: http://comments.gmane.org/gmane.comp.kd ... .pim/23269
I had the same problem. Just unchecked the "empty trash on exit" option and Kmail returned to normal operation.
Sorry for my bad English. I I do not fully mastered that language.
