After upgrading from 14.04 to 15.10 I get black terminal style login screen. When I log in I get root terminal with prompt. I do not know how to get past that nor do I want that. Any help appreciated.
problems upgrading from 14.04 to 15.10
How did you perform the upgrade?
Normally, big jump upgrades, such as going directly from 14.04 to 15.10 are not or recommended (except for LTS-to-LTS upgrades), so i am kinda surprised it jumps ahead so much, but then again *buntu releases have much shorter lifespans so the only version it can upgrade to would be WilyOn 14.04, the default upgrade setting is lts-to-lts.
As a start, log in at the terminal and then simply type:
startx
And post the exact error message(s) you get, if any.
I pressed "upgrade" in muon update manager where it told me a new version was available.
When I log in I get some stuff about Read only file system Then
bash: cannot create tmp file for here-document: read only file sytem
Startx results in
(EE)
Fatal server error:
(EE)could not create lock file in /tmp/.tx0-lock
(EE)
(EE)
please consult the The X.Org Foundation support at http://wiki.x.org
for help
(EE)
xinit:giving up
xinit:unable to connect to xserver: connection refused
xinit:server error
xauth: error in locking authority file home/xx/xauthority
Startx results in
(EE)
Fatal server error:
(EE)
(EE)
for help
(EE)
xinit:giving up
xinit:server error
a side note
This OS is installed on an external HD. I can access the file system when plugged in to an operating computer.
I already have 15.10 on a couple other computers plus Ubuntu 14.04 and Mint and 3 versions of windows. I really liked Kubuntu 14.04 the best and would revert back to it if I could.
One of the major changes to Ubuntu from 15.04 is the adoption of systemd. Under 14.04 you were using an init system called upstart then when upgrading to 15.10 it will have attempted at least to install systemd. Systemd is very much different to upstart and 14.04 was not set up to use systemd. Unless you decide to install 15.10 from scratch you will need to set up 15.10 to use systemd. Then it will probably work. Good luck.
Originally posted by Bushant View PostI pressed "upgrade" in muon update manager where it told me a new version was available.
Startx results in
(EE)
Fatal server error:
(EE)
(EE)
for help
(EE)
xinit:giving up
xinit:server error
a side note
Log in at the terminal again , and type:
df -h.
This will show how much space is on each partition you have
This is very unlikely to have anything to do with systemd
I have used 28 %. 242 Gig out of 915G. I have been searching the systemd thing and have not found any way to enable or install yet.
I sure hate to reinstall from scratch but if I did and reinstalled 14.04 would it be safe to upgrade to 16.04 in July or whenever that debuts?
Originally posted by Bushant View PostI have used 28 %. 242 Gig out of 915G.
Also, to see what your permissions are, this command will list them
ls -al /
Also more info about 'some stuff about read only file system' might help - if you have a disk error, fdisk can run during boot, putting the partition in read-only mode (for safety reasons) while it does it's thing. Can you add more details about this part?
If it is a space issue, that can be addressed somewhat, we can do things to clear up some space. If it is a permissions problem, that is actually an easy thing to fix.
Upgrading from LTS to LTS is officially supported, and is actually tested, though not many volunteer to do so.
Originally posted by Bushant View PostI can only vaguely reply because now I am getting the dreaded grub rescue prompt. All partitions had lots of room best I recall. I will have to fix this grub thing and report back.
I have a similar problem. I am using my laptop because the video on my desktop quit. I have narrowed that to either the DVI cable or - I hope not - a dead monitor. I decided to use my old laptop for now. It had 12.04 on it. I went into monu update's settings and changed it from only LTS to Normal updates. Now it would get the 15.10 update so I could update to the latest versioin... or so I thought. Now It boots to TTY1. Startx says failuar to connect to socket. Plenty of disk space and only 2 partions one is swap.Can I fix this? If not can I save my personal files?Last edited by steve7233; Feb 21, 2016, 10:02 PM. Reason: I bummped the mousepad and messed up the typing.Just to remind users and devs that Ubuntu and its flavors have a long way to go to be as usr friendly as they should be.
So lag, much slow...
I just did a similar upgrade (14.04 to 15.10), I got the prompt as well but was able to get past it and get 15.10 up and running. But, it lags so much! About 2/3 of the time, a mouse click anywhere results in a halt of the entire system of several seconds (I can actually read about a page on my kindle between the time that I click and the time that something happens). Also sometimes when I am typing (like as I type this message, or search for a program) there is a similar lag.
My computer is a little old (Lenovo X230T bought in 2012), is it just that Kubuntu now consumes so much processing power that my machine can't handle it? Is there some graphics stuff that I can turn down or something? Some processes running in the background that might be taking up all the memory? How do I figure out what is causing this?
Thanks for your help, I really appreciate it.
Jason
According to system monitor, I am running 257 processes, using about 33% of CPU, 2.3/7.5 gigs of memory, and 0/2.3 gigs of swap. When I look at the graphs ("system load" tab), they look like the attached pictures, with one or more of the CPUs jumping up to 100% then back down. I have no idea how to interpret this.
I found this thread (https://www.kubuntuforums.net/showth...s-problem-back), could I be experiencing this problem as well? Earlier today i was trying to watch a video (.mp4 saved on my external drive), after a few minutes the screen went black, then to the login prompt like I had put the computer to sleep and just woken it up; when I logged on I got an error message about ksmserver not being able to run, and about 14 crash reports about akonadi. I tried watching the video again, but the video froze while the audio kept playing, and the mouse and keyboard were unresponsive. I ended up turning off the computer and booting up in windoze.
Jason
Well it's hard to tell, by the time I see the spike and then click on the other tab, the list of processes changes. I keep seeing "baloo_file_extractor" and "kwin_x11" and "plasma shell" come to the top, but then (for example) as an active window, like the browser, freezes, it comes to the top, jumps to 25-30%, then says "disk sleep" then back to a percentage.
But, when the whole system freezes, so does the system monitor, so I have no idea what process (if any) might be causing the freeze.
Jason
