Hello, I'm fairly new to Kubuntu, but I've been running 15.10 on an ASUS X551M for while now, and using a VGA cable to connect to a second monitor, and it has been working very well.
A few days ago, it began behaving erratically though:
When I plug the VGA cable in, my laptop screen goes black.
I can see my cursor on the second monitor, but it can move only up and down against the left edge of the monitor. The rest of it is black as well.
Restarting the computer does not solve it.
I also entered into Display Configuration and clicked Reset and Defaults, but this has not worked either.
After I unplug the cable, the laptop screen comes back on, and I often get messages that krunner and/or Plasma have crashed. The taskbar disappears and re-loads, and the position of previously-open windows hops around.
I would be grateful for any advice--thank you very much!
