Sleeping Wireless USB Adapter
    I bought a Belkin wireless USB adapter that works fine unless I put the PC to sleep then resume. After resuming, the adapter is not active and the network applet says Wi-Fi is disconnected. It will work if I remove and re-insert the adapter. This is very annoying. I have read many posts but nothing I tried worked.
    Thanks Teunis.
