Just encoutered the weirdest bug.... on Kubuntu 15.10.
On login, system work as expected, tab-alt switches window and setting custom shortcut for window works OK.
However, after enabling NumLock, tab-alt and others KDE shortcuts (alt+F2) stops working (they just do nothing, but copy paste works fine for instance).
Disabling num lock restore the default tab-alt behavior.
Does any one have any clue on this one? Seems really weird.
Thanks!
(nota: i had been fiddling around with my XKB settings to transform my CapsLock to an End key, but I'm pretty sure I reverted this and this should have no effect anymore, just mentioning cause this implied `rm /var/lib/xkb/*.xkm`)
Thanks!
