Language selector in system tray?
    Hi!
    I just upgraded from 14.04 to 15.10, and ran into a problem. I use two languages, Swedish and Danish, and have used the language selctor in the system tray to switch between them. Now, in 15.10, I cannot find any such switcher. I have set both Swedish and Danish as available languages in the System Settings - Translations (I belive it's Translations, I have the Swedish menu).
    Anyone that can assist me in getting the language switch back?
    Best,
    Magnus
    The setting is still available in systemsettings where you configure layouts. A disclaimer I run tanglu 3 and it might be on a older version.
    Sent from my Nexus 6 using Tapatalk
      Ah... I found it! But not in Layout, in Input - Keyboard (layouts). Now it seems to work again. Thanks!
