Having stayed away for as long as possible, I tried to upgrade from Utopic to Vivid last night.
/usr/bin/python3.4 does exist, and appears to run.
Now apt-get reports unmet dependencies for kubuntu-desktop:
apt-get -f wants to remove kubuntu-desktop, and I assume that's not a good idea. Any suggestions?
kubuntu-desktop
Error in function:
SystemError: E:Sub-process /usr/bin/dpkg returned an error code (1)
Error in sys.excepthook:
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 102, in apport_excepthook
pr.add_proc_info(extraenv=['PYTHONPATH', 'PYTHONHOME'])
File "/usr/lib/python3/dist-packages/apport/report.py", line 521, in add_proc_info
raise ValueError('%s does not exist' % self['ExecutablePath'])
ValueError: /usr/bin/python3.4 (deleted) does not exist
Original exception was:
Could not install the upgrades
The upgrade has aborted. Your system could be in an unusable state. A
recovery will run now (dpkg --configure -a).
dpkg: dependency problems prevent configuration of kubuntu-desktop:
kubuntu-desktop depends on baloo-kf5; however:
Package baloo-kf5 is not installed.
dpkg: error processing package kubuntu-desktop (--configure):
dependency problems - leaving unconfigured
kubuntu-desktop
The following packages have unmet dependencies: baloo : Depends: baloo4 but it is not going to be installed kubuntu-desktop : Depends: baloo-kf5 but it is not going to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
