Keyboard Not Work in Chromium [Not an ibus issue]
    I have an older AMD 64 computer with a keyboard (not USB) that works fine with Kubuntu 14.04 except in Chromium.
    I read previous postings re this issue and followed their instructions for removing the ibus. (In Terminal: sudo killall ibus.) I then rebooted but still have the same problem of the keyboard not working in Chromium. In Terminal I again ran "sudo killall ibus" and got a message stating "ibus: no process found."
    I have no idea how to proceed from here. Any help would be appreciated.
    killall ibus won't do it.
    killall ibus-daemon
    No need for sudo/
      Thanks for trying blackpaw, but after pasting "killall ibus-daemon" from your post into Terminal and then rebooting my keyboard still does not work in Chromium.
      Any other suggestions?
        Don't reboot - ibus will restart each time.
        - Close Chrome
        - killall ibus-daemon
        - Start Chrome
        You'll have to do this each time you logon. Its only a workaround till the kubuntu devs create a permanent fix.
          Thanks blackpaw! That enabled me to use my keyboard in Chromium.
            Excellent.
              How can this the mandate to do when opening the computer to automatically run
                make a script for it and set up to autorun on log in using System Settings -> startup / shutdown ->autostart . use the add script button
                the script would be a simple text file that contains
                #/bin/bash
                killall ibus-daemon
                then save it. not sure if it needs to be executable or not for autostarting a script. if it fails make it executables (rt.click properties in dolphin or chmod +x)
                (top of thread: thread tools)
                  #/bin/bash
                  killall ibus-daemon
                  thanks sithlord48 ..!!!!
                    your welcome.
