Just did an 'in place' upgrade from 12.04 to 14.04. For the most part, it worked, and I'm now addressing some issues. One of those is that I usually use the desktop cube, and while I have desktop effects turned on, and cube selected, the pager just switches from one desktop to the next. No animation of any kind -- not even 'slide'. It turns out that desktop effects are not turned on, and when I try to turn them on, I get an error message (see screenshot). When I click on 'details' for the error message, it just says that technical limitations don't allow for a full explanation (or similar), and below that, it just reports that desktop effects are not turned on.
I am using the recommended nVidia driver for this machine.
A second item is that with 12.04, my wallpaper would show up translucently behind the panel / kicker (whatever they call it now). In the screenshot, you see that it is now just medium grey. I see no way to change that.
Thanks.
Frank.
Thanks.
Frank.
