I think I made a mistake with a fresh install of 13.10 32-bit on Samsung NC10 atom powered netbook.
When I put the battery in and start up I get GUI issues and have no battery options for power management in System Settings Power Management.
So far I have no workaround. Isimply given up, ALT-TABBED to an open terminal session and shutdown that way.
Removing the battery and running on power adaptor power resolves GUI issues, but I need to be able to use it in battery mode.
Is there a way of getting the right software for System Settings Power Management or do I need to reinstall with the battery in place?
If there is a fix, what are names of the packages I should get?
I hope I can get them without the battery installed or do it through the terminal.
