Originally posted by SteveRiley
View Post
Grub problems after installation, as always.
Depending on the specific options specified in the dd command, it can. If one is "wiping" by writing zeroes to disk, it will take a bit to get to 32 gb of them. It is done when you get your prompt back.
I use PartedMagic's Erase Disk program. It gives good visual feedback. It will give a time left to finish and a time for how long it has taken so far. My 16 GB PNY took close to two hours to zero-wipe.GigaByte GA-965G-DS3, Core2Duo at 2.1 GHz, 4 GB RAM, ASUS DRW-24B1ST, LiteOn iHAS 324 A, NVIDIA 7300 GS, 500 GB and 80 GB WD HDD
