Hi all,
I have two battery's. One built in and the other Slice battery. Kubuntu first drains the Slice battery which is ofcourse the default behavior and I have no issues with that. But after it drains the Slice battery, it says that battery has reached critical state and shutdowns/suspends the computer. It does not use the builtin battery. How can I remedy this issue?
Best regards,
Best regards,
