I'm not sure if this is the correct thread, or if my question should go to "software support" so please kindly advise if it needs to be relocated.
I've installed kubuntu 12.04 LTS on a netbook, with KDE backports so to get 4.11, it works great as usual
I have set oxygen windows theme which provides a nice contrast when using notebook. Usually for desktop computers I also set the
desktop them to oxygen (or androbit), but this is not enough efficient for nomads with notebooks, it needs a better contrast so
I have set "Air for ultra portables".
The problem I'm facing is this: the panel icons (scissor, speaker, usb, network ...) are white on white. Hardly seeing them.
As long as the setting is a black panel it's ok, but for a grey panel I need a good looking icons with a nice contrast.
And I have not found how to change the panel icons. All icons change i did have no effect on the panel icons.
I also noticed in the desktop theme settings we can go to the details tab and at the bottom of the list there is a choice
for the icons, it points to "air for ultra portable icons" by default. I think this icon setting is the one for the panel icons but KDE
does not ship with any icon set black for a white/grey background panel so i'm stuck with my problem.
I think the default panel icon set for Air and air for ultra portables should be changed because it really is not efficient, but
for now how can I solve this problem manually ?
Thanks in advance.
Thanks in advance.
