I'm experiencing a problem after having upgraded my system to the latest KDE version via the "kubuntu backports" repository.
It seems that something has been screwed up with the graphics configuration, I'm not sure if its about fglrx or the X server.
I'm not able to enable the desktop effects, if I try to do that (in System Settings > Desktop Effects > advanced tab) I can only choose Xrender compositing, while before the upgrade I was using OpenGL (not sure about the version, I think 2.0).
As a result, the usage of the system is rather sluggy, when I move a window it is redrawn very slowly and so on, I'm sure that you have understood the problem.
As I said, I suppose that something in the fglrx or X configuration has gone wrong during the upgrade; I've also tried to reinstall fglrx, that sometimes has solved the problem in similar circumstances, but this time I haven't got any result.
I'm posting some info about my system, if there is anything else that I should provide, please ask.
As you can see, the output of glxinfo seems to suggest that there is something wrong, and in the /etc/X11/ folder, there isn't a xorg.conf file.
Any suggestion about how to solve this problem?
~$ uname -a Linux stefano-TravelMate-5720 3.2.0-53-generic-pae #81-Ubuntu SMP Thu Aug 22 21:23:47 UTC 2013 i686 i686 i386 GNU/Linux
~$ lspci | grep VGA 01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV610/M74 [Mobility Radeon HD 2400 XT]
~$ glxinfo name of display: :0 X Error of failed request: BadRequest (invalid request code or no such operation) Major opcode of failed request: 139 (ATIFGLEXTENSION) Minor opcode of failed request: 66 () Serial number of failed request: 13 Current serial number in output stream: 13
~$ ls -alR /etc/X11/ /etc/X11/: totale 92 drwxr-xr-x 10 root root 4096 set 6 17:24 . drwxr-xr-x 156 root root 12288 set 7 11:30 .. drwxr-xr-x 2 root root 4096 apr 24 15:32 app-defaults drwxr-xr-x 2 root root 4096 set 5 2012 cursors -rw-r--r-- 1 root root 13 apr 23 2012 default-display-manager drwxr-xr-x 4 root root 4096 apr 23 2012 fonts -rw-r--r-- 1 root root 17394 dic 3 2009 rgb.txt lrwxrwxrwx 1 root root 13 mag 1 2012 X -> /usr/bin/Xorg drwxr-xr-x 3 root root 4096 apr 23 2012 xinit drwxr-xr-x 2 root root 4096 gen 23 2012 xkb -rw-r--r-- 1 root root 117 mag 6 2012 xorg.conf.original-0 -rwxr-xr-x 1 root root 709 apr 1 2010 Xreset drwxr-xr-x 2 root root 4096 gen 17 2013 Xreset.d drwxr-xr-x 2 root root 4096 gen 17 2013 Xresources -rwxr-xr-x 1 root root 3730 gen 20 2012 Xsession drwxr-xr-x 2 root root 4096 set 7 11:30 Xsession.d -rw-r--r-- 1 root root 265 lug 1 2008 Xsession.options -rw-r--r-- 1 root root 601 apr 23 2012 Xwrapper.config /etc/X11/app-defaults: totale 244 drwxr-xr-x 2 root root 4096 apr 24 15:32 . drwxr-xr-x 10 root root 4096 set 6 17:24 .. -rw-r--r-- 1 root root 6530 mar 7 2012 Bitmap -rw-r--r-- 1 root root 431 mar 7 2012 Bitmap-color -rw-r--r-- 1 root root 6589 mar 7 2012 Bitmap-nocase -rw-r--r-- 1 root root 176 mar 7 2012 Clock-color -rw-r--r-- 1 root root 10027 ott 31 2011 Editres -rw-r--r-- 1 root root 2893 ott 31 2011 Editres-color -rw-r--r-- 1 root root 3184 ott 31 2011 Viewres -rw-r--r-- 1 root root 973 ott 31 2011 Viewres-color -rw-r--r-- 1 root root 19328 mar 7 2012 XCalc -rw-r--r-- 1 root root 10325 mar 7 2012 XCalc-color -rw-r--r-- 1 root root 3505 mar 7 2012 XClipboard -rw-r--r-- 1 root root 20 mar 7 2012 XClock -rw-r--r-- 1 root root 245 mar 7 2012 XClock-color -rw-r--r-- 1 root root 767 mar 7 2012 XConsole -rw-r--r-- 1 root root 3128 mar 7 2012 Xditview -rw-r--r-- 1 root root 1375 mar 7 2012 Xditview-chrtr -rw-r--r-- 1 root root 15689 mar 7 2012 Xedit -rw-r--r-- 1 root root 5536 mar 7 2012 Xedit-color -rw-r--r-- 1 root root 825 ott 31 2011 Xfd -rw-r--r-- 1 root root 4778 ott 31 2011 XFontSel -rw-r--r-- 1 root root 65 mar 7 2012 Xgc -rw-r--r-- 1 root root 2353 mar 7 2012 Xgc-color -rw-r--r-- 1 root root 106 mar 7 2012 XLoad -rw-r--r-- 1 root root 121 mar 7 2012 XLogo -rw-r--r-- 1 root root 215 mar 7 2012 XLogo-color -rw-r--r-- 1 root root 730 mar 7 2012 Xmag -rw-r--r-- 1 root root 6116 mar 7 2012 Xman -rw-r--r-- 1 root root 248 ott 31 2011 Xmessage -rw-r--r-- 1 root root 920 ott 31 2011 Xmessage-color -rw-r--r-- 1 root root 1107 mar 7 2012 XMore lrwxrwxrwx 1 root root 15 apr 18 14:05 XScreenSaver -> XScreenSaver-gl -rw-r--r-- 1 root root 16927 gen 31 2012 XScreenSaver-gl -rw-r--r-- 1 root root 16927 gen 31 2012 XScreenSaver-nogl -rw-r--r-- 1 root root 3871 gen 16 2012 XSm -rw-r--r-- 1 root root 6628 ago 11 2011 Xvidtune /etc/X11/cursors: totale 44 drwxr-xr-x 2 root root 4096 set 5 2012 . drwxr-xr-x 10 root root 4096 set 6 17:24 .. -rw-r--r-- 1 root root 27 nov 20 2010 core.theme -rw-r--r-- 1 root root 32 nov 20 2010 handhelds.theme -rw-r--r-- 1 root root 108 ago 26 2012 oxy-black.theme -rw-r--r-- 1 root root 106 ago 26 2012 oxy-blue.theme -rw-r--r-- 1 root root 108 mag 26 2010 oxy-white.theme -rw-r--r-- 1 root root 110 ago 26 2012 oxy-yellow.theme -rw-r--r-- 1 root root 106 ago 26 2012 oxy-zion.theme -rw-r--r-- 1 root root 31 nov 20 2010 redglass.theme -rw-r--r-- 1 root root 33 nov 20 2010 whiteglass.theme /etc/X11/fonts: totale 16 drwxr-xr-x 4 root root 4096 apr 23 2012 . drwxr-xr-x 10 root root 4096 set 6 17:24 .. drwxr-xr-x 2 root root 4096 apr 23 2012 misc drwxr-xr-x 2 root root 4096 apr 23 2012 Type1 /etc/X11/fonts/misc: totale 16 drwxr-xr-x 2 root root 4096 apr 23 2012 . drwxr-xr-x 4 root root 4096 apr 23 2012 .. -rw-r--r-- 1 root root 6270 nov 17 2010 xfonts-base.alias /etc/X11/fonts/Type1: totale 16 drwxr-xr-x 2 root root 4096 apr 23 2012 . drwxr-xr-x 4 root root 4096 apr 23 2012 .. -rw-r--r-- 1 root root 154 apr 22 2010 xfonts-mathml.scale -rw-r--r-- 1 root root 2654 nov 18 2010 xfonts-scalable.scale /etc/X11/xinit: totale 20 drwxr-xr-x 3 root root 4096 apr 23 2012 . drwxr-xr-x 10 root root 4096 set 6 17:24 .. -rw-r--r-- 1 root root 164 ago 11 2011 xinitrc drwxr-xr-x 2 root root 4096 mar 8 2013 xinput.d -rwxr-xr-x 1 root root 46 ago 11 2011 xserverrc /etc/X11/xinit/xinput.d: totale 32 drwxr-xr-x 2 root root 4096 mar 8 2013 . drwxr-xr-x 3 root root 4096 apr 23 2012 .. lrwxrwxrwx 1 root root 32 mar 8 2013 all_ALL -> /etc/alternatives/xinput-all_ALL -rw-r--r-- 1 root root 1152 giu 7 2011 default -rw-r--r-- 1 root root 601 giu 7 2011 default-xim -rw-r--r-- 1 root root 636 giu 7 2011 lo-gtk lrwxrwxrwx 1 root root 30 mar 8 2013 lo_TH -> /etc/alternatives/xinput-lo_TH -rw-r--r-- 1 root root 474 giu 7 2011 none -rw-r--r-- 1 root root 643 giu 7 2011 th-gtk lrwxrwxrwx 1 root root 30 mar 8 2013 th_TH -> /etc/alternatives/xinput-th_TH -rw-r--r-- 1 root root 610 giu 7 2011 th-xim /etc/X11/xkb: totale 8 drwxr-xr-x 2 root root 4096 gen 23 2012 . drwxr-xr-x 10 root root 4096 set 6 17:24 .. /etc/X11/Xreset.d: totale 12 drwxr-xr-x 2 root root 4096 gen 17 2013 . drwxr-xr-x 10 root root 4096 set 6 17:24 .. -rw-r--r-- 1 root root 205 apr 1 2010 README /etc/X11/Xresources: totale 12 drwxr-xr-x 2 root root 4096 gen 17 2013 . drwxr-xr-x 10 root root 4096 set 6 17:24 .. -rw-r--r-- 1 root root 319 lug 1 2008 x11-common /etc/X11/Xsession.d: totale 80 drwxr-xr-x 2 root root 4096 set 7 11:30 . drwxr-xr-x 10 root root 4096 set 6 17:24 .. lrwxrwxrwx 1 root root 40 set 7 11:30 10fglrx -> /etc/alternatives/i386-linux-gnu_10fglrx -rw-r--r-- 1 root root 2030 gen 20 2012 20x11-common_process-args -rw-r--r-- 1 root root 878 mar 30 2010 30x11-common_xresources -rw-r--r-- 1 root root 389 mar 22 2012 35x11-common_xhost-local -rw-r--r-- 1 root root 187 lug 1 2008 40x11-common_xsessionrc -rw-r--r-- 1 root root 1568 mag 20 2011 50x11-common_determine-startup -rw-r--r-- 1 root root 146 gen 20 2012 60x11-common_localhost -rw-r--r-- 1 root root 768 gen 20 2012 60x11-common_xdg_path -rw-r--r-- 1 root root 80 apr 12 2012 60xdg-user-dirs-update -rw-r--r-- 1 root root 337 mar 23 2012 70gconfd_path-on-session -rw-r--r-- 1 root root 1024 feb 22 2012 75dbus_dbus-launch -rw-r--r-- 1 root root 143 nov 28 2012 80appmenu -rw-r--r-- 1 root root 142 nov 28 2012 80appmenu-gtk3 -rwxr-xr-x 1 root root 2392 feb 26 2013 80im-switch -rw-r--r-- 1 root root 326 apr 13 2012 80kubuntu-xmodmap -rw-r--r-- 1 root root 1027 feb 24 2012 90consolekit -rw-r--r-- 1 root root 591 ago 24 2011 90gpg-agent -rw-r--r-- 1 root root 629 mar 30 2010 90x11-common_ssh-agent -rw-r--r-- 1 root root 166 lug 1 2008 99x11-common_start
