Hello.
When I try to login (enter uname, password) a black screen with commands appear for a fraction of second and the last thing I see is : "Saned disabled; edit /etc/default/saned"
Then the login screen appears again.
I can login by clicking cntrl-shift - f1 and then login through console, though.
How can I login to see my desktop?
Thank you.
Thank you.
so I ran an update, it started downloading, I had to free another 10 mb for the update installation so I deleted all my Documents folder, about 30Mb when finished the update I had 2.9GB free
