Hello,
I've just installed 12.04. Didn't upgrade from 11.10 due to some network problems, so I burned a CD.
Sometimes I got a popup saying KDE detected that some of the internal devices were removed, asking to definitively forget this devices, I allways selected NO. Then go to systems settings -> multimedia -> phonon. After test channels, I could use amarok with no problems.
Today the icon of the sound card was shaded, only a dummy was OK. After remove pulseaudio, I got a lot of devices, but none of them works!!!!
If I choose HDA INTEL PCH (ALC892 Analog) it pops up a warning "device is not working, switching to "default"... Default does not works either...
How can I unintall-reinstall sound card? Should I remove-reinstall phonon?
Please let me know if there is a way to solve...
Thanks.
Thanks.
