Some persisting problems after install
    Hi!
    Been using Ubuntu several years and was imposed to change desktop due to Unity. I have a fresh 11.10 install with KDE 4.7.4 and 3 users.
    There is a threshold changing desktop but I'm getting more and more comfortable.
    I've run into the following issues
    Note: I'm running with Swedish language so my referenced to windows might not be the exactly correct English.
    1. There is something wrong with Nepomuk. I have a Nepomuk-Service connection - KDE Crashhandler (Details: nepomukservicestub Process-id: 21796 Signal: Aborted (6)) window constantly open. If I close it, it immideately opens again. If I select Restart Program and Close it opens again. I have googled and found some threads about similar problems but no solution.
    2. When shuting down I have to make sure that everyapplication is closed (windows) or it will halt and in weird mode without a proper window handler.
    Ex If I select shutdown with firefox open, firefox stays open and the only way I can close it is via Ctrl-Q. Note. Off cource the Nepomuk window from question1 also has to be closed manually.
    3. Sometimes (maybe one in 10) when I select Lock Screen the Screen is locked and I get the proper Enter Password dialog BUT the screen is not "blacked out". The full desktop is still visible. It is locked and I have to enter password to access, but .....
    4. When I get an indication of an update being available and click on it the muon application starts without asking for sudo rights, so I can't install the updates. I also had to add kdesu to the command in the main menu. Note. Nowdays I mostly use terminal but ...
    /Palle
    Re 3. I've also seen that (maybe one time in 50) when the system is quite busy. I haven't looked into a solution.
    Re 2., does this always happen? It shouldn't, unless KWin has had issues during operation. (It's normal for windows to lose decorations and desktop for a few seconds before they actually close, but not as seriously as you describe.)
      On 2. Yes every time, no exception. Could ity actually be that the real culprit is the Nepomuk issue that "halts" the regular shut down process. No matter if I had other windows open there is always that last Nepomuk error window to close before shutdown.
        About issue 1.)
        Also adding a copy of the developer information from the crashhandler (note. I have made an error report some time ago).:
        Application: Nepomuk-tjänstanslutning (nepomukservicestub), signal: Aborted
        [Current thread is 1 (Thread 0xb5679710 (LWP 5866))]
        Thread 3 (Thread 0xb3b84b70 (LWP 5867)):
        #0 0xb7771b2c in QEventDispatcherGlib:rocessEvents(QFlags<QEventLoop::ProcessEventsFlag> ) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #1 0xb77421dd in QEventLoop:rocessEvents(QFlags<QEventLoop::ProcessEventsFlag> ) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #2 0xb7742421 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsF lag>) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #3 0xb764590b in QThread::exec() () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #4 0xb76459fb in QThread::run() () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #5 0xb76487b3 in ?? () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #6 0xb6045d31 in start_thread () from /lib/i386-linux-gnu/libpthread.so.0
        #7 0xb612c0ce in clone () from /lib/i386-linux-gnu/libc.so.6
        Backtrace stopped: Not enough registers or memory available to unwind further
        Thread 2 (Thread 0xb31ffb70 (LWP 5869)):
        #0 0xb6018d10 in clock_gettime () from /lib/i386-linux-gnu/librt.so.1
        #1 0xb769f7d5 in ?? () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #2 0xb77724b6 in ?? () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #3 0xb777280a in ?? () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #4 0xb7771053 in ?? () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #5 0xb77710ed in ?? () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #6 0xb5f5e88c in g_main_context_prepare () from /lib/i386-linux-gnu/libglib-2.0.so.0
        #7 0xb5f5f637 in ?? () from /lib/i386-linux-gnu/libglib-2.0.so.0
        #8 0xb5f5fc2a in g_main_context_iteration () from /lib/i386-linux-gnu/libglib-2.0.so.0
        #9 0xb7771b37 in QEventDispatcherGlib:rocessEvents(QFlags<QEventLoop::ProcessEventsFlag> ) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #10 0xb77421dd in QEventLoop:rocessEvents(QFlags<QEventLoop::ProcessEventsFlag> ) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #11 0xb7742421 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsF lag>) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #12 0xb764590b in QThread::exec() () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #13 0xb7722e2d in ?? () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #14 0xb76487b3 in ?? () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #15 0xb6045d31 in start_thread () from /lib/i386-linux-gnu/libpthread.so.0
        #16 0xb612c0ce in clone () from /lib/i386-linux-gnu/libc.so.6
        Thread 1 (Thread 0xb5679710 (LWP 5866)):
        [KCrash Handler]
        #7 0xb7899424 in __kernel_vsyscall ()
        #8 0xb6087c8f in raise () from /lib/i386-linux-gnu/libc.so.6
        #9 0xb608b2b5 in abort () from /lib/i386-linux-gnu/libc.so.6
        #10 0xb60bddfc in ?? () from /lib/i386-linux-gnu/libc.so.6
        #11 0xb60c8bc2 in ?? () from /lib/i386-linux-gnu/libc.so.6
        #12 0xb60c9862 in ?? () from /lib/i386-linux-gnu/libc.so.6
        #13 0xb60cc94d in free () from /lib/i386-linux-gnu/libc.so.6
        #14 0xb628480f in operator delete(void*) () from /usr/lib/i386-linux-gnu/libstdc++.so.6
        #15 0xb628486b in operator delete[](void*) () from /usr/lib/i386-linux-gnu/libstdc++.so.6
        #16 0xb3c1cea1 in ?? () from /usr/lib/kde4/nepomukfilewatch.so
        #17 0xb3c1bf2f in ?? () from /usr/lib/kde4/nepomukfilewatch.so
        #18 0xb7749b7d in QMetaObject::metacall(QObject*, QMetaObject::Call, int, void**) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #19 0xb7754685 in QMetaCallEvent:laceMetaCall(QObject*) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #20 0xb775bb52 in QObject::event(QEvent*) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #21 0xb6419d84 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/i386-linux-gnu/libQtGui.so.4
        #22 0xb641f133 in QApplication::notify(QObject*, QEvent*) () from /usr/lib/i386-linux-gnu/libQtGui.so.4
        #23 0xb7046971 in KApplication::notify(QObject*, QEvent*) () from /usr/lib/libkdeui.so.5
        #24 0xb774319e in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #25 0xb7746f93 in QCoreApplicationPrivate::sendPostedEvents(QObject* , int, QThreadData*) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #26 0xb77470ec in QCoreApplication::sendPostedEvents(QObject*, int) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #27 0xb77716a4 in ?? () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #28 0xb5f5f25f in g_main_context_dispatch () from /lib/i386-linux-gnu/libglib-2.0.so.0
        #29 0xb5f5f990 in ?? () from /lib/i386-linux-gnu/libglib-2.0.so.0
        #30 0xb5f5fc2a in g_main_context_iteration () from /lib/i386-linux-gnu/libglib-2.0.so.0
        #31 0xb7771ada in QEventDispatcherGlib:rocessEvents(QFlags<QEventLoop::ProcessEventsFlag> ) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #32 0xb64d1e7a in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4
        #33 0xb77421dd in QEventLoop:rocessEvents(QFlags<QEventLoop::ProcessEventsFlag> ) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #34 0xb7742421 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsF lag>) () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #35 0xb774719d in QCoreApplication::exec() () from /usr/lib/i386-linux-gnu/libQtCore.so.4
        #36 0xb6417924 in QApplication::exec() () from /usr/lib/i386-linux-gnu/libQtGui.so.4
        #37 0x0804ae3b in ?? ()
        #38 0xb6073113 in __libc_start_main () from /lib/i386-linux-gnu/libc.so.6
        #39 0x0804b151 in _start ()
