Hi everybody,
I just re-installed Kubuntu by formatting "/" partition and "home" partition as well.
Now when I log in I got a couple of error popup (I can't remember them exactly, my Kubuntu PC is at home):
It seemes like I can't modify files in /home/.kde
(for example, if I open dolphin with SUDO, I'm able to change dolphin settings and save them... but they're shown only if I use dolphin as superuser).
Don't know if it can help, but I can't either copy hidden files in /home/.kde
I'm not sure if I'm explaining this issue clearly
Any idea how to solve this
thanks a lot!
Andy
/home/.kde/share/dolphin.??? not writable
- the same for knotify and another file.
morover, anything I try to change on settings or applications aren't saved.
For example:
- I change view properties in dolphin (i.e. show hidden files), I apply to every folder but nothing happens
- I change an application icon but nothing changes
- In Amarok, I set my library folder and when I close and re-open Amarok, it is not saved
thanks a lot!
Andy
