Hello:
I am writing this post because I have a problem, really annoying bad problem with the keyboard and touchpad!
First, I had recently moved from Kubuntu 9.10 (Karmic Koala) to Kubuntu 11.10. Almost everything is working on 11.10 as it was working 9.10, except for the Keyboard and Touchpad. >
I had tried before 10.04, 10.10, and 11.04, and the problem was the same, I reported, but no luck to find a solution.
The problem is this:
When I install Kubuntu (from version 9.10 to 11.10) the keyboard failed to works when the computer goes to and comes back from sleep or hibernate mode. It does not work at all! So I had to forced the computer to shutdown.
I tried different things, from the Internet communities of Ubuntu, and I found this solutions:
But this does not do anything at all. The problem keeps happening!
Also:
This one fixed the problem with the keyboard in all versions
, but in versions 10.04 and up (not in 9.10) gave me problem with the touchpad. The computer does not recognize the touchpad and I can not use it at all! >
Then I began to search for answer on how to fix this problem too, but not good luck on it.
I only found the following:
That allowed to use the touchpad as a regular mouse, but I have to start konsole everytime that I started the computer, and then insert manually the code in order to be able to use the touchpad again (this is frustrating!). And with this, the system still does not recognize the touchpad.
I decided to change to the latest version of kubuntu, since people kept telling me it was a bad idea to stick with 9.10 because it does not has any support from kubuntu community anymore, and the kde environment of that version has to many bugs. Sincerely, 9.10 gave me less problem than newer versions! >
Can someone help me, fix this problems, before I decided to go back to 9.10, please?!!!
About the Hardware of the computer:
Change the line on document {/etc/default/grub} named {GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"} to {GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_sleep=nonvs"}; do {sudo update-grub} and reinstall computer.
Also:
Change the line on document {/etc/default/grub} named {GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"} to {GRUB_CMDLINE_LINUX_DEFAULT="quiet splash atkbd.reset"}; do {sudo update-grub} and reinstall computer.
echo "options psmouse proto=imps" |sudo tee -a /etc/modprobe.d/psmouse.conf; sudo modprobe -r psmouse; sudo modprobe psmouse
- Processor: Inter Core 2 Duo Processor T6500 / 2.10 GHz
- Graphics: Mobile Intel Graphics Media Accelerator 4500MHD
- Display: 14.1" / 1280 x 800
- Total Memory: 4 GB
- Storage approx: 320 GB
- Model: Sony Vaio VGN-CS320J
